Simple glue-up question
« back to Joinery forum
Forum topic by SuperCubber posted 12-23-2015 02:12 AM 1067 views 0 times favorited 12 replies Add to Favorites Watch
View SuperCubber's profile
SuperCubber
1048 posts in 2525 days
12-23-2015 02:12 AM
Topic tags/keywords: panel glue-up
Hey guys,
I think this will be a simple answer, but I can’t decide which route to take.
I’m about to glue up a panel that will be roughly 24” wide. I am trying to decide the best method to keep this panel flat over time. Aesthetics don’t matter for what it will be used for, but it needs to stay flat.
I can either edge join 5 boards which are each about 5” wide, or I can rip them to a narrow width, such as 1” and join them, like an edge-grain cutting board (obviously more work).
The 4/4 lumber has been acclimating to my shop for several months.
What do you guys think gives me the best chance of keeping it flat?
Thanks,
-- Joe | Spartanburg, SC | "To give anything less than your best is to sacrafice the gift." - Steve Prefontaine
12 replies so far
View 000's profile
000
2859 posts in 1140 days
#1 posted 12-23-2015 02:24 AM
What kind of wood? Approx. 2” rips would be my Guess
View jerryminer's profile
jerryminer
944 posts in 1682 days
#2 posted 12-23-2015 04:42 AM
Simple answer? Hmmmm…
Quarter-sawn lumber is the most stable , everything else being equal. Splitting a 5” board into 5 pieces and then gluing them back together in the same orientation won’t accomplish anything. Ripping flat-sawn stock into strips and turning the strips to create a quarter-sawn panel would lead to greater stability. but if the edges of your 5” pieces have vertically-oriented grain already, then ripping and rolling would not provide a benefit.
Here’s as simply as I can put it: Do whatever you need to do to get as close to quarter-sawn material as you can.
View jkinoh's profile
jkinoh
95 posts in 2138 days
#3 posted 12-23-2015 12:29 PM
I wouldn’t be afraid to glue up 5” boards. Should be fine as long as they are all flat to start and edges are accurate 90deg.
-- Why buy it for $300 when you can make it for $500!!
View rwe2156's profile
rwe2156
3235 posts in 1721 days
#4 posted 12-23-2015 03:44 PM
Clamp up with cauls and keep in cauls a few days.
Keep it as thick as you can as long as you can.
Keep it in a stable environment. I put in plastic bags or take in the house.
If it cups you can always go back and split it and reglue.
SuperCubber
#5 posted 12-23-2015 04:15 PM
Thanks for the replies, guys. If it cups, I am hosed, because it will be in another state. I’m more concerned about twisting than cupping.
It is plain sawn, so perhaps I’ll cut it, rotate it and glue it.
Thanks again,
View pintodeluxe's profile
pintodeluxe
5819 posts in 3054 days
#6 posted 12-23-2015 04:54 PM
“4/4” and “needs to stay flat” don’t go together. I have gone exclusively to 5/4 lumber for that very reason. I would agree to rip it into strips and show the quartersawn sides. It will be a lot of work at the jointer, but well worth it in the end.
View sawdustdad's profile
sawdustdad
367 posts in 1126 days
#7 posted 12-25-2015 05:16 PM
Thanks,- SuperCubber
If an absolutely flat panel were critical, I’d be veneering an MDO or MDF core. If i could tolerate very minor variations to perfectly flat, I’d be using plywood, either apple ply or marine grade ply. the next most stable would be lumber core or any furniture grade veneered ply, and then, the least stable, would be solid wood.
Regardless of how you cut the wood, glue it up, etc., there are no guarantees it will stay flat.
Of course, “flat” is a relative term. As is the “risk” of it not staying that way. You’ve got to make that call.
-- Murphy's Carpentry Corollary #3: Half of all boards cut to a specific length will be too short.
rwe2156
#8 posted 12-25-2015 06:00 PM
It is plain sawn, so perhaps I ll cut it, rotate it and glue it.
Thanks again,
- SuperCubber
Be careful on that rotating if the grain direction is reversed you may have a devil of a time if you plan on hand planing.
Dittos on the 5/4. I’m a much happier camper since I’ve gone to that. If you have a log milled I’ve found you have to watch the sawyers they are so used to cutting 4/4 and 8/4 they get 5/4 messed up pretty easy. Last go round I had to stand there and measure every single cut the guy just couldn’t compute it on his machine I guess.
SuperCubber
#9 posted 12-25-2015 09:31 PM
If an absolutely flat panel were critical, I d be veneering an MDO or MDF core. If i could tolerate very minor variations to perfectly flat, I d be using plywood, either apple ply or marine grade ply. the next most stable would be lumber core or any furniture grade veneered ply, and then, the least stable, would be solid wood.
Of course, “flat” is a relative term. As is the “risk” of it not staying that way. You ve got to make that call.
- sawdustdad
I could totally use plywood. I was so stuck on figuring a way to use this hardwood that I totally ignored the idea of using plywood. Thanks for slapping my forehead!
View AlaskaGuy's profile
AlaskaGuy
5002 posts in 2550 days
#10 posted 12-26-2015 02:23 AM
Yep, no worry with todays plywood.
SuperCubber
#11 posted 12-26-2015 02:49 AM
Haha
View bandit571's profile
bandit571
22026 posts in 2924 days
#12 posted 12-26-2015 05:29 AM
Maybe add a “Breadboard” edge to the ends? Tends to keep the panels I make flat.
