Couple questions about finishing up my 2nd end grain cutting board
Forum topic by DrHorrible posted 12-22-2015 08:02 PM 486 views 0 times favorited 3 replies Add to Favorites Watch
View DrHorrible's profile
DrHorrible
8 posts in 1512 days
12-22-2015 08:02 PM
Couple quick questions to help me get this thing right:
1) What grits do you recommend for tackling the end grain? Should I start lower than I normally would? I know this takes forever with ROS, so I made sure all my measurement would help start me at the smoothest state.
1) What’s the best way to check for glue before I apply the oil to finish it out? On my first cutting board, I didn’t see the glue until applying the oil, I’d like to remedy that this time. Perhaps water or mineral spirits?
Thanks all!
Michael
3 replies so far
View Andre's profile
Andre
1576 posts in 1680 days
#1 posted 12-22-2015 10:46 PM
Use a scraper to check for any glue residue?
View conifur's profile
conifur
955 posts in 1026 days
#2 posted 12-22-2015 11:24 PM
You can wipe it with MS, paint thinner, naphtha, to find glue.
View bonesbr549's profile
bonesbr549
1469 posts in 2941 days
#3 posted 12-23-2015 03:19 PM
as others stated wipe down with MS, and for checking for glue, take a water base dye dilute with water and apply damp cloth it will show the glue like majic. Sand and the dye will come right off, since its not a stain the pigment will not go into the grain and be removed easily. Learned that “trace coat” trick from Charles Neil! Works like a charm. I use it on everything now. It will also show you any sanding marks too!
Good luck and post some pictures.
