2 sided tape
« back to Woodturning forum
Forum topic by FancyShoes posted 12-22-2015 07:15 PM 854 views 0 times favorited 7 replies Add to Favorites Watch
View FancyShoes's profile
FancyShoes
550 posts in 1392 days
12-22-2015 07:15 PM
What do you prefer to use for 2sided tape when turning?
7 replies so far
View bondogaposis's profile
bondogaposis
4769 posts in 2379 days
#1 posted 12-22-2015 07:22 PM
This is the best I’ve found.
-- Bondo Gaposis
View Andre's profile
Andre
1888 posts in 1833 days
#2 posted 12-22-2015 10:47 PM
Lee Valley has some really good tape.
View TheDane's profile
TheDane
5448 posts in 3690 days
#3 posted 12-22-2015 11:05 PM
I have been using Turner’s Tape from Peachtree.
There is also a double-sided Duck Tape that I found at Walmart that Cap’n Eddie uses.
View bearkatwood's profile
bearkatwood
1597 posts in 1039 days
#4 posted 12-22-2015 11:33 PM
Duct tape has a great one that I use. For years I used mounting tape that was a bit thicker, but I have been happy with the duct tape.
-- Brian Noel
View JoeinGa's profile
JoeinGa
7736 posts in 2034 days
#5 posted 12-23-2015 12:00 AM
I prefer THIS ... because I have had almost ZERO luck with both 2-sided tape and using paper in between the mounting block and the piece being turned.
TheDane
#6 posted 12-23-2015 01:04 AM
... because I have had almost ZERO luck with both 2-sided tape …
The key to using just about any double-sided tape is to apply the tape, press the workpiece to the tape, then apply tail-stock pressure for 10-15 minutes. I have never had one let go.
View JeffP's profile
JeffP
573 posts in 1419 days
#7 posted 12-23-2015 01:41 AM
Here’s a tape tip that I discovered quite by accident while doing a DIY HVAC install recently.
Ever have trouble getting the liner off of double-sticky tape? Try bending the corner and digging at it with your finger nails and cursing a lot?
Here’s the easy way…take a piece of regular tape (masking tape, blue tape, duct tape, anything sticky), and stick it real good to the corner of the non-stick backer you’re trying to peel off. Then use the regular tape to pull the backer away from the double-stick tape. Works like magic. Sticks just well enough to the slick backer stuff that you can just peel it back easy as you please.
You’re welcome!
-- Last week I finally got my $*i# together. Unfortunately, it was in my shop, so I will probably never find it again.
