Wood discoloration
Forum topic by Lynchee posted 12-22-2015 06:02 PM 732 views 0 times favorited 12 replies Add to Favorites Watch
View Lynchee's profile
Lynchee
18 posts in 1442 days
12-22-2015 06:02 PM
Hi. 1st post (of course it’s a question).
I’ve been making cutting boards for Christmas, and used a piece of maple that was discolored from being outside.
Anyway, I planed it until the wood looked good, but when I started cutting it, the inside (end grain) is gray. The outside looks pretty normal, but the whole inside looks like poop.
I’m not going to use it because it looks bad, but what is it? Is it mildew? I’ll post a pic of that helps.
Thanks in advance!!
12 replies so far
View TheFridge's profile
TheFridge
10705 posts in 1684 days
#1 posted 12-22-2015 06:14 PM
Pics help
Lynchee
#2 posted 12-22-2015 06:22 PM
View LiveEdge's profile
LiveEdge
594 posts in 1818 days
#3 posted 12-22-2015 06:27 PM
I think you are seeing a potentially normal variation of maple. It can have a gray tone at times in my experience.
Lynchee
#4 posted 12-22-2015 08:01 PM
- LiveEdge
Did you notice the “good” color around the outside?
If it’s “normal”, then I feel better. Maybe I’ll finish it and keep for myself. It just looks dirty.
Thanks for the response!
View shampeon's profile
shampeon
1882 posts in 2381 days
#5 posted 12-22-2015 08:08 PM
Take an off cut and soak in some mineral oil. Does it still look grey and muddy?
And yeah, some maples can have that grey tone, particularly soft maple. Adding a finish changes it significantly.
View Tennessee's profile
Tennessee
2893 posts in 2712 days
#6 posted 12-22-2015 09:05 PM
I just sent out some boards that had a piece or two of that maple with the gray streaks in it. Personally, I thought it gave otherwise colorless maple some character.
After the walnut oil finish, it amplified the grain and the color.
Each to their own!
Lynchee
#7 posted 12-23-2015 12:17 AM
- shampeon
Yeah, it looked darker.
View Ger21's profile
Ger21
1075 posts in 3329 days
#8 posted 12-23-2015 12:25 AM
If it was exposed to water, than water will seep into the endgrain and cause staining. There’s no way to remove it.
-- Gerry, http://www.thecncwoodworker.com/index.html http://www.jointcam.com
View WDHLT15's profile
WDHLT15
1792 posts in 2674 days
#9 posted 12-23-2015 02:02 AM
It is gray stain. It is an enzymatic oxidation reaction with the sugar in the wood caused by high temp and high humidity. Maple is very prone to it, and if the air flow on the drying stacks is not high, you will get the gray stain.
Here is some information on it.
http://www.fpl.fs.fed.us/documnts/fplrp/fpl_rp654.pdf
Lynchee
#10 posted 12-23-2015 03:39 PM
- WDHLT15
Good info, thanks very much.
So, it’s safe to use as a cutting board if I wanted to finish it up?
I was thinking it might be mildew, but guess not.
Thanks again everyone
View Yonak's profile
Yonak
986 posts in 1719 days
#11 posted 12-23-2015 03:51 PM
Honestly, Lynchee, I had to look hard to even see what you are talking about. I wouldn’t worry one whit about it. Everyone will see the great work you’ve done and only you will see your perceived imperfection.
WDHLT15
#12 posted 12-24-2015 01:45 AM
Safe to use. I agree with Yonak. It is hardly perceptible. In many cases, it adds character to bland maple.
