gluing up small *thin* panels
« back to Joinery forum
Forum topic by XquietflyX posted 12-22-2015 05:08 PM 1740 views 0 times favorited 20 replies Add to Favorites Watch
View XquietflyX's profile
XquietflyX
339 posts in 1046 days
12-22-2015 05:08 PM
Topic tags/keywords: question
I have some oak that is cut into 2 1/2” by 8 1/4” by 3/16” thick strips. I need to glue 4 of them into a small panel for the top of a jewelry box I’m building for my wife for Xmas.
My issue is i’m having a hard time figuring the proper way to clamp them to each other as they are so thin.
Does any one have tips for gluing small thin strips in to one larger panel? the final piece will be 10” by 8 1/4”.
thanks!
-Chris
-- You can tell a lot about your wife by her hands, for example if they are around your throat she's prolly pissed off at you...
20 replies so far
View WoodNSawdust's profile
WoodNSawdust
1417 posts in 1262 days
#1 posted 12-22-2015 05:11 PM
Use blue painters tape to connect two panels, flip over and open like a hinge, add glue, and then close and use more tape to hold together. Repeat with other panels.
XquietflyX
#2 posted 12-22-2015 05:12 PM
will that be tight enough without clamping?
- WoodNSawdust
View mahdee's profile
mahdee
3948 posts in 1853 days
#3 posted 12-22-2015 05:12 PM
If you are going to use this as a veneer to put over a substrate, then glue the 2-1/2 strips one at a time to the sub.
-- earthartandfoods.com
View ChrisK's profile
ChrisK
1983 posts in 3167 days
#4 posted 12-22-2015 05:20 PM
Use epoxy instead of wood glue. The tape and good wood glue should be just fine.
-- Chris K
WoodNSawdust
#5 posted 12-22-2015 05:25 PM
That depends on if the wood is intended to be structural or not. Tests have shown that the glue is as strong or stronger than the wood. Just pull the tape tight so there are no gaps and the pieces fit tight together.
- WoodNSawdust
- XquietflyX
XquietflyX
#6 posted 12-22-2015 05:40 PM
Its not structural, but theres no substrate below it. It is going in place of where glass would go if the box had a glass see through top.
- WoodNSawdust
- XquietflyX
- WoodNSawdust
XquietflyX
#7 posted 12-22-2015 05:43 PM
this is not Mine, but the one i’ve built is this same style. in my case instead of glass i’m using the wood strips.
View shampeon's profile
shampeon
1775 posts in 2269 days
#8 posted 12-22-2015 05:49 PM
You can use tape. The technique is to press one side of the tape on one strip with your finger, stretch the tape out with the other hand, then press the other side down on the other strip. Do this maybe every inch on the strip, then flip it and do the other side.
View TheFridge's profile
TheFridge
9879 posts in 1572 days
#9 posted 12-22-2015 05:52 PM
as long as the surfaces are coated well it shouldn’t matter whether it’s clamped or not.
View splintergroup's profile
splintergroup
2210 posts in 1308 days
#10 posted 12-22-2015 06:00 PM
I have used masking tape many times as a “clamp” on thin or irregularly shaped parts.
As WoodNSawdust says, use the blue masking tape (it has a bit more stretch). I like the 1” wide stuff.
Typically I will apply a thin bead of glue to the edges, enough to fully cover but avoiding excessive squeeze out.
Join the edges with the pieces lying on a flat surface (that glue won’t stick to).
Place a piece of tape (about 2” long) securely on one of the pieces, then while pressing your thumb down on the end, stretch the tape over the joint and press it down on the other side. The tape will spring back, effectively applying force to the joint.
I like to apply a strip of tape about every 2”.
After securing one side of your panel, flip the panel and tape the other side the same way. You can’t really over stretch the tape, if it breaks, just do it again with a little less force.
You can easily check the panel alignment and adjust for flush as you tape. Usually everything stays flush, but it won’t hurt to place you panel between some flat boards (non-stick) to keep things flat while the glue sets.
XquietflyX
#11 posted 12-22-2015 06:30 PM
Thanks i’ll try this once i get home.
Join the edges with the pieces lying on a flat surface (that glue won t stick to).
After securing one side of your panel, flip the panel and tape the other side the same way. You can t really over stretch the tape, if it breaks, just do it again with a little less force.
You can easily check the panel alignment and adjust for flush as you tape. Usually everything stays flush, but it won t hurt to place you panel between some flat boards (non-stick) to keep things flat while the glue sets.
- splintergroup
View rwe2156's profile
rwe2156
3036 posts in 1566 days
#12 posted 12-22-2015 10:11 PM
Don’t like the tape myself. Instead I would use cauls covered with packing tape and light clamp pressure.
Keeping them flat is the biggest problem.
I would leave them in the cauls quite a while because on panels that thin the glue itself can cause some cupping.
If you just tape them and glue them I can almost guarantee problems keeping them flat.
View joey502's profile
joey502
544 posts in 1603 days
#13 posted 12-23-2015 04:21 AM
I use clamps, light pressure, with cauls. The oak pieces in the pics are a dash over 1/4” when glued, I planned and sanded after the glue dried.
View Texcaster's profile
Texcaster
1287 posts in 1759 days
#14 posted 12-23-2015 10:50 AM
I use this method to join 3mm structural guitar tops and backs.
Small sprung joints
Minimum clamp pressure , weight the joint.
-- Mama calls me Texcaster but my real name is Mr. Earl.
View Jim Finn's profile
Jim Finn
2666 posts in 3007 days
#15 posted 12-24-2015 01:49 AM
I glue up panels like this with masking tape as mentioned and then I put rubber bands around it to act as a clamp.
-- No PHD just a DD214 and a GED Website> https://craftingcouple.com
