Table saw blade
Forum topic by Glen posted 12-22-2015 02:06 PM 1041 views 0 times favorited 26 replies Add to Favorites Watch
View Glen's profile
Glen
116 posts in 3074 days
12-22-2015 02:06 PM
Topic tags/keywords: question blade
Is there a 10” table saw blade that does not leave any marks in all kinds of woods? I am sick of having to run pieces through the jointer after every time I cut them on the table saw.
-- Glen
26 replies so far
View conifur's profile
conifur
955 posts in 1148 days
#1 posted 12-22-2015 02:08 PM
Freud’s glue line rip or Foresters same, are about the best, it also depends on your fence is set up correctly.
View tomsteve's profile
tomsteve
783 posts in 1216 days
#2 posted 12-22-2015 02:12 PM
theres some glue line rip blades out there but nothing beats a run across the jointer.
if youre having bad saw marks you may have to do some alignment work on the fence.
View GT350's profile
GT350
368 posts in 1978 days
#3 posted 12-22-2015 02:24 PM
I have the Forrest Woodworker II, I really have to look close to see the saw marks, I still like to run them over the jointer or take a hand plane to it.
Mike
View HokieKen's profile
HokieKen
4989 posts in 1135 days
#4 posted 12-22-2015 02:24 PM
Agree with above on double checking your fence alignment. Even with a cheap blade you should get clean cuts for a while. I’d check fence alignment and arbor runout before spending $ on more blades.
-- Kenny, SW VA, Go Hokies!!!
View mahdee's profile
mahdee
3883 posts in 1764 days
#5 posted 12-22-2015 02:33 PM
Yes, make sure the back of your blade is not touching the wood as you are running it through. If it does, not only it leaves the marks on the board, it could potentially throw the piece right at your face.
-- earthartandfoods.com
View Glen's profile
Glen
#6 posted 12-22-2015 02:56 PM
What is the best way to be sure that I have perfect fence alignment?
-- Glen
View knotscott's profile
knotscott
8012 posts in 3372 days
#7 posted 12-22-2015 02:59 PM
There are many blades that will leave a glue-ready edge, but none will leave a finish-ready edge. The blade is only one component of a larger equation. The table saw setup and arbor runout are factors. A throat insert that doesn’t flex is crtiical. The shape of the wood prior to cutting is a big factor…it helps a lot of the material is flat and straight to start with so it’s no rocking and moving during the cut. Technique and feed rate are also factors.
Typically speaking, blades with that leave the cleanest edges are also the most prone to burning, because they simply put more carbide against the edge of the wood. Many are higher tooth blades, but there are also several lower tooth count blades that have extremely tight side clearances that leave a very clean edge.
What saw and blade are you currently using?
Tips for Picking Saw Blades
View WoodNSawdust's profile
WoodNSawdust
1417 posts in 1173 days
#8 posted 12-22-2015 03:01 PM
Do a internet search for table saw alignment.
Basically:
mark a tooth on the saw blade.
Measure the distance between the tooth and the right miter saw slot
turn the saw blade to the back
measure again.
If the distance is different then you need to align the saw. Alignment procedures vary depending on the type of saw.
Do the same thing with the fence
lock the fence down
measure the distance between the front of the fence and the same edge of the same miter slot
measure the distance at the back of the fence
they should be the same, if not then align the fence.
View BurlyBob's profile
BurlyBob
5491 posts in 2262 days
#9 posted 12-22-2015 03:07 PM
Glen I had the same problem. I tried several different times to correct it ending frustrated. I finally broke down and bought the Woodpecker saw gauge. Using it to realign my fence made a significant difference.
View Glen's profile
Glen
#10 posted 12-22-2015 03:35 PM
knotscott, I am using a 36 tooth Irwin thin kerf blade on a 10” Craftsman contractors saw.
-- Glen
View bearkatwood's profile
bearkatwood
1572 posts in 1008 days
#11 posted 12-22-2015 03:38 PM
Sounds like your saw needs a tune up. Check the blade alignment with the saw top and fence alignment.
-- Brian Noel
View ThomasChippendale's profile
ThomasChippendale
244 posts in 929 days
#12 posted 12-22-2015 04:30 PM
One way to check if the blade is parallel to the fence is to look for the saw marks on the both right and left piece of wood after ripping. Visualize that the blade is not parralel so that the front (towards you when you push the stock) cuts the right side of the stock and the rear of the blade, assuming your guide is on the right hand side, rubs on the outer side of the plank. You will then have downwards marks on the right side plank and upwards marks on the left side piece. You then adjust your guide until you get a mix of up and downwards marks on the inner side, that is as good as you will get and good enough for any glue joint. You can imagine that otherwise, your cut has a wider kerf and a concave surface is left on both sides of the plank being ripped.
-- PJ
knotscott
#13 posted 12-22-2015 04:49 PM
- Glen
If it’s one of the Irwin Marathon or Irwin Classic blades, changing blades would likely help a lot. A 40T or 50T blade from the Irwin Marples, Freud Diablo, CMT ITK Plus, and DeWalt Precision Trim series should all be an improvement, and most can be picked up locally in the $30-$40 range. Between getting a new blade and tuning your saw up, you should be closer to optimum performance from the saw.
As shown below: the pic at the top is about as good as it’ll get with a 40T blade:
View Glen's profile
Glen
#14 posted 12-22-2015 07:57 PM
I have the Irwin Marathon blade. The saw marks from my blade look like the third picture down from the top. I am going to go shopping for one of the other blades that you have listed. Then I am going to get the Woodpecker saw gauge that BurlyBob did and re-align my fence and blade.
-- Glen
View jdh122's profile
jdh122
1008 posts in 2814 days
#15 posted 12-22-2015 08:04 PM
That Woodpecker saw gauge looks nice and I bet it works beautifully. But if you have a dial indicator you can easily screw a board to your miter gauge and attach your dial indicator to that and get quite an exact measurement of how far out of parallel your top is out from your blade. For the money saved you could afford to buy a Woodworker II blade rather than the Marathon.
-- Jeremy, in the Acadian forests
