Bottle stoppers
Forum topic by Dudley posted 01-13-2010 09:14 PM 1487 views 0 times favorited 7 replies Add to Favorites Watch
View Dudley's profile
Dudley
742 posts in 3282 days
01-13-2010 09:14 PM
Topic tags/keywords: question
What size dowel do you folks use for turning bottle stoppers using regular tapered corks. TKS Dudley
-- Dudley Young USN Retired. Sebastian, Fl.
7 replies so far
View reggiek's profile
reggiek
2240 posts in 3291 days
#1 posted 01-13-2010 09:18 PM
It depends on what shape you want to make….I usually look at a minimal size of a square over 3” X 3”...remember you can always reduce the size easily – increasing requires a lot more effort.
Dudley
#2 posted 01-13-2010 09:25 PM
reggick: I’m asking about the dowel that you glue in the end of the block to chuck up on and to mount the cork when done turning. TKS 3/8—5/16?
reggiek
#3 posted 01-13-2010 09:37 PM
ahh..my bad…(plop) – thats the sound of me hitting my forehead with my ice cream cone – I usually start with a block chucked up between centers (sized as above)....turn to round (sometimes I will leave some square areas for design – but one side has to be rounded) and then turn a tenon on a rounded side that is approximately 1/16 less (I like my stoppers not to overhang the cork and possibly catch on the bottle) then the widest diameter of the cork (I use a caliper to measure as corks vary alot in size…even in the same batch)....that also leaves me the ability to sand a bit before attaching to the stopper. It also is stronger then gluing a dowel to the turning and then too the cork.
View coloradobob's profile
coloradobob
26 posts in 3576 days
#4 posted 01-14-2010 03:58 PM
Most of the corks are predrilled to fit a 3/8 dowel rod. I do not make many of this style of stopper I prefer SS (stainless steel ends) myself.
-- coloradobob
Dudley
#5 posted 01-14-2010 04:18 PM
Thanks all: Didn’t know the corks came pre-drilled. Haven’t received my order yet. Will get the mandrel and do some S/S and chrome also.
reggiek
#6 posted 01-14-2010 08:47 PM
I’ve never used pre drilled corks (I just would get some at the local Michaels craft store).....like you I wasn’t aware that they did (I would still turn my own tenon instead of using a dowel though). I have switched over to turning for SS stoppers myself after finding SS Niles for a source. here is the site for anyone wanting a good, reasonable priced source SS Niles Stoppers I found this site being mentioned on here before and that was how I came aware of it – I had a wonderful conversation with Ruth Niles….the owner…when I made my first order….great person and great product.
Dudley
#7 posted 01-14-2010 10:53 PM
Got my corks today and they are not pre-drilled so I can use any size dowel I want.
