Forum topic by spalted | posted 12-22-2015 05:56 AM | 969 views | 0 times favorited | 9 replies | ![]() |
Hi I was given a ton of elbows and y fittings for 4” pvc that I want to use for a dust collection system. I believe they are sized for schedule 40. They are too large for the green pvc drain pipe of the same 4” diameter. Is there a way I can use these fittings with the cheaper thinner wall pvc I find at lowes or am I forced to use sc40 pipe only? |
9 replies so far
#1 posted 12-22-2015 12:04 PM |
Depends on how much effort you want to put into it. You can heat thinwall and stretch it (or shrink it) with a heat gun, or you could use any of a lot of methods of filling the gap. That would include wraps of duct tape, wooden doughnuts, jamming the thinwall into the fitting past the larger joint area, and probably several dozen other ways I haven’t thought of. If it was me I think I’d try to figure out the cheapest way…either toss the fittings and buy thinwall ones, or stick with the schedule 40 pipe. -- Our village hasn't lost it's idiot, he was elected to congress. |
#2 posted 12-22-2015 12:36 PM |
There are reducers available that glue into a schedule 40 fitting that adapt it over to the S&D size pipe. You will just have to figure if it works out cost wise. From a plumbing supply house this stuff can be pretty cheap compared to prices at Home Depot or a local hardware store. |
#3 posted 12-22-2015 01:03 PM |
I remember seeing a home improvement show where a plumber had pieces of PVC glued together and he needed to make changes. He cut the PVC pipe off as it left the fitting and then used a special tool to ream out the PVC that was glued into the fitting. You could find a short piece of schedule 40 pipe, glue it into the fittings, cut it off, and then use the above mentioned tool to ream it out to the correct size for the pipe you need. -- "I love it when a plan comes together" John "Hannibal" Smith |
#4 posted 12-22-2015 02:11 PM |
When I checked into using PVC for dust collection schedule 20 fits the best, but could not find any. -- Knowledge and experience equals Wisdom, Michael Frankowski |
#5 posted 12-22-2015 02:23 PM |
You can get schedule 10 pvc from several places. The OD is the same, the wall is thinner. http://www.mcmaster.com/#2426k25/=10clh1q sch 10 from McMaster http://www.usplastic.com/catalog/item.aspx?itemid=102753&catid=528 reemer -- Chris K |
#6 posted 12-22-2015 08:06 PM |
They make fitting adapters, but it might cost more than just buying new fittings. http://www.homedepot.com/p/NDS-4-in-x-4-in-PVC-DWV-x-Sewer-and-Drain-Adapter-3P16/100377417 |
#7 posted 12-22-2015 11:22 PM |
Thanks for all the replies. I found the adapters at lowes too and after a few minutes I realized I’d probably spend less just buying new Ys and elbows for the thin wall pipe. Well here I go assembling my new dc system! |
#8 posted 12-22-2015 11:59 PM |
Spalted, if you haven’t already spent the money, follow Fred’s suggestion and wrap the green tubing with duct tape until the diameter gives a nice tight fit with the schedule 40 fittings. I used gorilla tape because it is very thick and didn’t require many wrappings. HTH -- Art |
#9 posted 12-23-2015 01:35 AM |
You could just use the southern-pride “there, I fixed it” solution. just butt the two things together with no particular care or interest in how well or unwell they mate…then “mate them” with duct tape. Actually, I would recommend this method, but with the “real” duct tape that pro’s use for HVAC installations. It is metal-backed peel & stick tape. You could darn near fix a blown engine block with that stuff. I just love it. Unlike “regular duct tape”, this stuff doesn’t dry out and fall off after a few months. You can find it next to the cheap duct tape in the HVAC aisle at Home Despot or Lowes. -- Last week I finally got my $*i# together. Unfortunately, it was in my shop, so I will probably never find it again. |
Forum | Topics |
Woodworking Skill Share
12029 |
Woodturning
2108 |
Woodcarving
431 |
Scrollsawing
340 |
Joinery
1370 |
Finishing
4904 |
6695 |
28058 |
CNC Woodworking
212 |
Hand Tools
5410 |
Jigs & Fixtures
1419 |
Wood & Lumber
6232 |
1388 |
Focus on the Workspace
2154 |
1187 |
Woodworking Trade & Swap
4756 |
LumberJocks.com Site Feedback
2200 |
Coffee Lounge
8845 |
