Porter Cable Router conversion
Forum topic by Yamamaha posted 01-13-2010 08:55 PM 1229 views 0 times favorited 2 replies Add to Favorites Watch
View Yamamaha's profile
20 posts in 2988 days
01-13-2010 08:55 PM
I just purchased a PC 7538 plunge router. It’s too late for the shoulda, woulda, coulda bought this or that one instead. Anyways, I want to turn this into a table setup.
Since this is the single speed 21,000 rpm model, I want to turn it into a cloned 7539, 5 speed model. It appears that speed controller switches don’t work with soft start motors…so I was contemplating buying all the parts which differ between the two above models. Looks like the parts total $124 fm Porter Cablle site.
Any thoughts on doing this?
Second question is in regards to llifts. Choices are kind of limited for plunge routers of this size….either the Router Raizer or the Unilift by Woodpecker’s. Anyone know of others which work on the large PC plunge’s?
2 replies so far
View RedShirt013's profile
219 posts in 3595 days
#1 posted 01-14-2010 12:25 AM
I’m not an expert in this area, but have you looked into rewiring and bypassing the “soft start” circuitboard inside the router, then just use a speed controller switch like you originally intended?
-- Ed
View Dusty56's profile
11819 posts in 3621 days
#2 posted 01-14-2010 04:22 AM
I read about the Triton routers on this site all of the time . Would it be any less expensive to buy the correct router rather than the router lift and retro-fitting all the pieces ?
