Gluing after tung oil?
Forum topic by Triman posted 01-13-2010 08:42 PM 5894 views 0 times favorited 6 replies Add to Favorites Watch
View Triman's profile
Triman
50 posts in 3545 days
01-13-2010 08:42 PM
I’m working on a project, where it would be much easier to finish with tung oil, then glue up the pieces. However, I’m worried that the glue bond might not be as strong after the tung oil, as opposed to gluing up the raw wood. Should I wait until after finishing to glue, or can I finish first, then glue?
Thanks in advance!
-- Bruce, San Jose, Ca www.spotofwood.com
View reggiek's profile
reggiek
2240 posts in 3233 days
#1 posted 01-13-2010 08:45 PM
I always glue up prior to finishing…to make sure I don’t have any glue spill over….and to insure the oil does not interfere with the glue bond.
View Gary's profile
Gary
9322 posts in 3396 days
#2 posted 01-13-2010 08:52 PM
ditto
View Ampeater's profile
Ampeater
440 posts in 3710 days
#3 posted 01-13-2010 08:59 PM
You can finish first and then glue up if you are careful. Use blue tape to cover any area that will have glue applied to it, apply the finish, and remove the tape. You should try this on some scrap, in order to be comfortable with it, before doing it on the final project.
-- "A goal without a plan is a wish."
View JohnGreco's profile
JohnGreco
284 posts in 3018 days
#4 posted 01-13-2010 09:34 PM
I have had great success using blue painters tape over the areas that will get the glue. I try to glue up as much as I can, but some parts are just easier to oil first. The edges under tape will get a little bit of oil from capillary action, so as long as the area isn’t super small, it should work well for you, too.
-- John
View Dez's profile
Dez
1166 posts in 4040 days
#5 posted 01-14-2010 12:18 AM
I have to agree with Ampeater and John, although I use the green painters tape – seems to be less bleed under the edge than the blue. In the cabinet shop where I sometimes work/play we almost always pre-finish before assembly, it is very difficult to get a good spray finish after the boxes are assembled.
-- Folly ever comes cloaked in opportunity!
View cmaeda's profile
cmaeda
205 posts in 3517 days
#6 posted 01-14-2010 01:23 AM
I use Ampeater’s way too. I try to pre finish everything but I use the green tape like Dez.
