Wood Identification, Ebony?
Forum topic by Bobby57 posted 12-22-2015 02:09 AM 993 views 0 times favorited 12 replies Add to Favorites Watch
View Bobby57's profile
Bobby57
14 posts in 791 days
12-22-2015 02:09 AM
I bought my house from an estate years ago and the previous owner was a carpenter / woodworker. The estate had left many items behind with my approval. One of those items was a 40 inch long log about 7 inches in diameter, it is almost black in color and is extremely heavy and dense. I had always assumed it was ebony but never confirmed it. I had always worked with wood but never turned wood till this past weekend after i bought a vintage Delta 1460 lathe which by the way works beautifully. What’s the best way to identify this wood? interested in turning with it when I have a little more practice. Thanks for your input
-- Bob, Carmel, NY
12 replies so far
View bearkatwood's profile
bearkatwood
1477 posts in 915 days
#1 posted 12-22-2015 02:54 AM
If that is indeed ebony or even african blackwood, you have a very pricey board there :) both run around $100 BF, Nice find. If it has a tangy stale coffee smell to it and it is JET black with some dark brown streaks it is ebony and if it smells sweet and floral and has some reddish hues and not quite black it is african blackwood. Wear a mask when turning it and use a vacuum, use mineral spirits on any parts that will be glued up and have fun with it.
-- Brian Noel
View rustynails's profile
rustynails
726 posts in 2432 days
#2 posted 12-22-2015 05:41 PM
If it is Ebony I dont think I would turn it as it is to pricey for all that wast????
Bobby57
#3 posted 12-22-2015 05:50 PM
Was thinking the same thing actually, maybe cut off a small piece and turn a plate instead of a bowl to minimize the waste but still get to see a finished ebony piece from my hands.
-- Bob, Carmel, NY
View LiveEdge's profile
LiveEdge
571 posts in 1524 days
#4 posted 12-22-2015 06:06 PM
You might be able to distinguish Ebony from African Blackwood by weight. You can either calculate the rough volume with geometry or even get a more accurate volume by dunking it in water and measuring the displacement. Blackwood is about 25% heavier (80lbs/cu ft) versus Ebony (60lbs/cu ft).
Actually, I came back to add that the water bath might give it to you right off. Blackwood sinks while Ebony floats.
Bobby57
#5 posted 12-22-2015 06:14 PM
I’ll try that in the bathtub, I’ll let you know what happens. Is there any way that it could be a species other than those two?
-- Bob, Carmel, NY
View tomsteve's profile
tomsteve
752 posts in 1123 days
#6 posted 12-22-2015 07:42 PM
take a sander and clean up a spot both on endgrain and face of log and post pics.
Bobby57
#7 posted 12-22-2015 08:03 PM
I’ll do that this evening
-- Bob, Carmel, NY
LiveEdge
#8 posted 12-22-2015 09:26 PM
One thing that has me puzzled is that both of the woods mentioned have light colored sapwood. I assume we are looking at the sapwood and not bark?
Bobby57
#9 posted 12-23-2015 02:28 AM
didn’t get to see if it floats, hand sanded the end a little and the side, but here are some more pics
-- Bob, Carmel, NY
LiveEdge
#10 posted 12-23-2015 04:06 AM
What about something like Bog Oak? Frankly I have no idea what it is because of the lack of obvious sapwood in a rough piece of timber. I’m interested in hearing what other people think.
View bobasaurus's profile
bobasaurus
3376 posts in 3087 days
#11 posted 12-23-2015 04:19 AM
Could be some variety of ironwood as well. But if that’s ebony, nice score.
-- Allen, Colorado (Instagram @bobasaurus_woodworking)
View TheFridge's profile (online now)
TheFridge
8856 posts in 1389 days
#12 posted 12-23-2015 04:37 AM
I thought ebony had really light colored sapwood.
A Rosewood maybe?
Cut the end grain with a sharp tool and take as close of a pic as you can. Pore size and density along with growth rings can help you identify the exact species if.
