Dowels vs screws
« back to Joinery forum
Forum topic by TinWhiskers posted 12-22-2015 12:53 AM 2382 views 0 times favorited 24 replies Add to Favorites Watch
View TinWhiskers's profile
TinWhiskers
179 posts in 947 days
12-22-2015 12:53 AM
Would love to make an Adironcack chair with dowels instead of screws. Maybe 3 bolts would be used. Would this stay together?
24 replies so far
View MadMark's profile
MadMark
979 posts in 1447 days
#1 posted 12-22-2015 01:03 AM
All depends on how you make it. If it was designed for gluing, no problem, but if the design is bad, forget it. Remember the wood will only do what wood will do.
View builtinbkyn's profile
builtinbkyn
2273 posts in 935 days
#2 posted 12-22-2015 01:24 AM
I’d like to hear what others think, but gluing could cause a problem. Being exposed to the elements, there will be a lot of movement seasonally and even day to day. The dowels are a rigid connection and really don’t allow for movement. They could also swell and crack the joint. Screws allow for some movement.
-- Bill, Yo!......in Brooklyn & Steel City :)
TinWhiskers
#3 posted 12-22-2015 01:28 AM
I’ve made about 10 of them. Never used dowels on anything. Seems like a good thing to learn. Not sure what you mean by ‘designed for gluing.’
MadMark
#4 posted 12-22-2015 03:49 AM
Designed for gluing is a design where no fasteners are needed because of the joinery. The loads are perpendicular to glue planes instead of parallel, compression loads instead of tension loads, etc
Screws get out of hand. They have their places, but to me, the fewer metal fasteners the better.
M
TinWhiskers
#5 posted 12-22-2015 05:29 AM
ahhhhh…I think I see. Might try one with less screws. Maybe an experimental for indoors. Thx for the input.
Kim
View jerryminer's profile
jerryminer
923 posts in 1436 days
#6 posted 12-22-2015 08:34 AM
I think you’ll be fine replacing screws with dowels—-as long as the dowels are made of a rot-resistant wood. I’ve repaired lots of outdoor furniture that was doweled together—with—I think—maple dowels, that rotted away long before the rest of the piece. Your dimensions are small enough (narrow pieces) that wood movement should not be an issue.
Are you familiar with Miller dowels? They are basically a direct replacement for screws. Miller Dowel
View AlaskaGuy's profile
AlaskaGuy
4122 posts in 2303 days
#7 posted 12-22-2015 11:42 AM
I ve made about 10 of them. Never used dowels on anything. Seems like a good thing to learn. Not sure what you mean by designed for gluing.
- TinWhiskers
If it ain’t broke don’t fix it.
View Sandra's profile
Sandra
7207 posts in 2069 days
#8 posted 12-22-2015 12:17 PM
Interested in the responses here. I’ve made 4 Adirondack chairs and I’m not a fan of how the screws look holding the back slats onto the upper support. The ones I made however were all painted bright colours, so the fasteners aren’t as noticeable.
-- No, I don't want to buy the pink hammer.
View dhazelton's profile
dhazelton
2766 posts in 2291 days
#9 posted 12-22-2015 01:09 PM
Why not just countersink the screw holes and use a plug cutter to cap them off?
TinWhiskers
#10 posted 12-22-2015 01:41 PM
If it ain t broke don t fix it.
- AlaskaGuy
I’ve seen chairs for sale with exposed screws. Instant turn off. Screws with caps a clear winner while not adding expense to building. Invisible fasteners one more step above. It aint brokoe, just better.
Interested in the responses here. I ve made 4 Adirondack chairs and I m not a fan of how the screws look holding the back slats onto the upper support. The ones I made however were all painted bright colours, so the fasteners aren t as noticeable.
- Sandra
Pardon my poor choice of pic to use. Normally when drilling I’ll make a straight line for the 2 dozen screws for the slats. I had a dumb ass day. Those and the seat slat screws I would like to hide. I use 3 shoulder bolts to attach the frame to the rocker base. Those will stay.
- dhazelton
Please scroll to the pic. Just trying for better.
View rwe2156's profile
rwe2156
2920 posts in 1475 days
#11 posted 12-22-2015 11:34 PM
Perhaps do the plugs a little smaller and try to match wood better?
TinWhiskers
#12 posted 12-22-2015 11:58 PM
- rwe2156
Thx. That chair is a 50% size chair. Would fit a 2 yr old well. Thus the plugs look big. I will try to see how small I can go. Plus line up the grain better. Still going to experiment with dowels. And the Miller dowels I have not heard of. Those deserve a look at.
Kim
View Fettler's profile
Fettler
200 posts in 1991 days
#13 posted 12-25-2015 07:46 AM
It’s all a matter of wood movement. The book understanding wood has a lot of information on the subject.
If you bind two piece of wood at 90 degree angles then you should only have to worry about the strength of the joint. If wood is bound parallel or less than 45 degrees it can get tricky. Screws or nails allow for more movement then glued joints.
For the back slats and chair bottom, one dowel centered would probably work. I’d cut my own dowels (you can make a dowel cutter from a hand plane iron) from the same species. For the legs I think lag bolts are still the best route.
-- --Rob, Seattle, WA
TinWhiskers
#14 posted 12-25-2015 12:54 PM
Have ordered the book . Thx for the tip.
I tried a chair with one screw in each back slat. Too much side movement in the back. Need two screws. Lag bolts for sure on the legs. Or shoulder bolts with a nut on the other end.
Never gave it a thought about making my own dowels. Huge thx for steering me that way.
Kim
TinWhiskers
#15 posted 01-16-2016 03:26 AM
Got the book. Need to read it.
Did do the chair. Came out well. Feels sturdy. No screws but for 2 shoulder bolts on each side as seen in the pic. Will be my shop chair till spring for testing.
