Cutting shapes
Forum topic by DavidSkaw posted 12-21-2015 11:56 PM 689 views 0 times favorited 4 replies Add to Favorites Watch
View DavidSkaw's profile
DavidSkaw
18 posts in 868 days
12-21-2015 11:56 PM
Hey All,
I am a new woodworker and have what might be a basic question but I can not find an answer anywhere.
how can I cut simple shapes from plywood.. I want to make a Shapes box. like this one.
http://lumberjocks.com/projects/99075
Or This one
http://lumberjocks.com/projects/101000
I have no idea how to cut the shapes..
I have a band saw, routers etc.. no scroll saw
Thanks for the help.
View Dallas's profile
Dallas
3599 posts in 2450 days
#1 posted 12-22-2015 12:55 AM
scroll saw or jig saw.
View patcollins's profile
patcollins
1683 posts in 2827 days
#2 posted 12-22-2015 01:02 AM
Best way is with a scroll saw so you can drill a small hole at a corner, insert blade and cut the shape out, sand down your shape and the drilled hole disappears.
Using a jig saw you will probably have to make a set of shapes separately because your cutout is going to be trashed.
View HokieKen's profile
HokieKen
4734 posts in 1101 days
#3 posted 12-22-2015 02:41 PM
Yep, scroll or jig saw. Scroll saw is definitely the best option for the reasons patcollins pointed out – get the cutouts and the shapes at the same time. If you don’t have access to a scroll saw a jig saw will do the job just fine. You’ll have to make the cutouts and then make the shapes from a different board though.
-- Kenny, SW VA, Go Hokies!!!
View xeddog's profile
xeddog
182 posts in 2970 days
#4 posted 01-16-2016 08:10 PM
Templates and spiral router bit. You would also need router guide bushings. I think this would give you the most consistent results if you wanted to make multiples.
