Working with burl for bottle openers?
Forum topic by BinghamtonEd posted 12-21-2015 05:47 PM 626 views 0 times favorited 1 reply Add to Favorites Watch
View BinghamtonEd's profile
BinghamtonEd
2298 posts in 2608 days
12-21-2015 05:47 PM
So a buddy of mine dropped off a couple of burl blanks (looks like walnut to me) that were too small for his use. The biggest one is about 12” long, 8/4 thick, and 3” wide. I have a couple of these inset bottle opener kits from Rockler, and was thinking of making bottle openers from the burl. I’ve never worked with burl before. I don’t have a lathe, the shaping will be done with spokeshave, dremel w/ sanding drum, and sandpaper.
These burls have not been stabilized. Is that something I should be doing for this application?
Normally, with straight-grained wood, I would run the grain along the length to provide maximum strength for the prying motion these will endure. Is this even a consideration with burl that has no discernible grain direction? I don’t want these to break, but it also doesn’t take much force to open a beer.
1 reply so far
View Nicky's profile
Nicky
695 posts in 4331 days
#1 posted 12-21-2015 07:30 PM
You’ll be fine. Burls are not known for their strength for the reasons you’ve mentioned already. But you going to be opening bottles; plenty of strengths for that applications.
Nice sharp spokeshave will do an excellent job of shaping.
If you have checks/cracks, you should stabilize them with CA glue. You can even finish with CA glue being careful not to glue your project to your hand … (experience talking)
Burls have some of the most beautiful patterns and will make nice bottle openers.
-- Nicky
