Hmmm, drill press fence question
Forum topic by Hopdevil posted 01-13-2010 02:01 AM 3927 views 0 times favorited 12 replies Add to Favorites Watch
View Hopdevil's profile
Hopdevil
217 posts in 2995 days
01-13-2010 02:01 AM
Topic tags/keywords: drill press fence question
Greetings!
I am in the process of building a drill press table & fence and I just had an oh-oh moment. The drill press is an old one. It’s a Fleetwood from 1979
The problem is that even with the piece of scrap wood sitting there as a fence, the handles on the drill press will hit the fence as they are turned. I’d be surprised if I was the first one to run into this issue. (I did search the forums to no avail)
Do I need to:
A. Shorten the length of the handles?
B. Remove one of the handles?
C. Adjust …..?
D. Stop being dain bramaged and just …..
Thanks in advance for your help!
Buzz!
Perspective
-- Buzz ---- Of all the things I have ever lost, I miss my mind the most.
12 replies so far
View papadan's profile
papadan
3584 posts in 3278 days
#1 posted 01-13-2010 02:08 AM
A picture of your setup would help. Can you cut down the hieght of the fence in the handle area? Use a shorter fence? As a last resort, shorten the handles on the DP.
View PineInTheAsh's profile
PineInTheAsh
404 posts in 3177 days
#2 posted 01-13-2010 02:15 AM
Yes, Hopdevil you are the first person on earth to ever experience this problem.
[he, he :)]
Two things… A “Fleetwood” from 1979?? That’s a new one on me. Who is actual manufacturer?
Where was it made?
For now, do NOT cut anything just yet.
And, a picture or pictures are not just not a nicety, they’re essential in allowing the world-class LJ board to render its full and proper magic.
Best,
Peter
Hopdevil
#3 posted 01-13-2010 02:46 AM
Sorry for the super size pictures :-)
papadan
#4 posted 01-13-2010 02:52 AM
You can’t even use a short bit, the handles would hit the table. If it were mine, I would cut the handles in half and rethread the ends that screw into the hub. Or cut in half and epoxy some nice wood knobs on them. LOL
View PaulfromVictor's profile
PaulfromVictor
228 posts in 3255 days
#5 posted 01-13-2010 02:57 AM
Mine did the same thing. I removed one of the handles and work with 2 only.
View Cory's profile
Cory
760 posts in 3329 days
#6 posted 01-13-2010 04:38 PM
for medium and long bits you could just create a notch in the fence to allow the handle to pass through, but I would shorten the handles and re attach the knobs with epoxy. You’ll give up some leverage but it shouldn’t be a big deal on a press that small.
-- The secret to getting ahead is getting started.
View SnowyRiver's profile
SnowyRiver
51457 posts in 3390 days
#7 posted 01-13-2010 05:54 PM
I have a commercially made table/fence on mine, and the fence is 3” high. I have to remove one of the press handles like some have said if I have the table up close to the chuck. I dont know that the fence would have to be 3” high though…It might help to have a shorter fence too.
-- Wayne - Plymouth MN
Rick Dennington
5701 posts in 3104 days
#8 posted 01-13-2010 09:35 PM
Greetings: I would make the fence not as tall as you have it. You can get by with a 2 1/2—3” fence with no problem. Another question: Do you have a quill drive that is at least 3+”? Make a shorter fence, and lower the table to clear the handles….... simple…...! But——- if you can’t do that, make the fence to clear the handles, and remove a handle…...you can get by with two, or even one, if necessary…... simple….... lol.
View iamwelty's profile
iamwelty
257 posts in 3025 days
#9 posted 01-14-2010 02:08 AM
Do you need to have the fence extend to the conflict area? If not cut it off or angle the fence
-- There is a fine line between eroticism and nausea...
View Dave's profile
Dave
26 posts in 2977 days
#10 posted 01-15-2010 05:45 PM
I had the same problem so i made my fence about 2.5” high and lowered my table, then maxed out my drill depth .
Then i raised my table up as far as i could go before hitting the fence. This worked for me .
I can use a 35mm bore bit for hinges a that is the shortest bit i will use. If all else fails cut the handles.
-- Dave
View closetguy's profile
closetguy
744 posts in 3801 days
#11 posted 01-15-2010 07:11 PM
I agree with DaveR. I had the same problem a few years ago and changed to a 1” fence and never missed the tall one. Usually the only thing I clamp to the fence is a right and left stop for repetitive drilling.
-- I don't make mistakes, only design changes....www.dgmwoodworks.com
View richgreer's profile
richgreer
4541 posts in 2984 days
#12 posted 01-15-2010 07:11 PM
I see nothing wrong is cutting a notch out of your fence. If you are going to put a t-track in the fence (good idea) it would have to be in 2 sections.
