Help need it identifying a bench plane
Forum topic by Alonso posted 01-12-2010 07:59 PM 2587 views 0 times favorited 21 replies Add to Favorites Watch
View Alonso's profile
Alonso
949 posts in 3115 days
01-12-2010 07:59 PM
Hey folks,
I recently got a “Stanley No 5 corrugated”, after a close inspection I came up to the conclusion that its not an Stanley, due to several factors, (I hope to be wrong)
I took several photos for you to please help me identify this plane correctly, is it a good quality plane?, the blade says “Ohio” and the main body “No 05” and that’s about it.
So if anyone knows anything about this plane I will appreciate your help a lot.
So what do you think, is it worth to keep it ?
Thanks
Alonso
-- The things I make may be for others, but how I make them is for me.
21 replies so far
View northwoodsman's profile
northwoodsman
242 posts in 3623 days
#1 posted 01-12-2010 08:10 PM
I think you may be right. You have a Stanley Lever Cap however. Go to http://www.hyperkitten.com/tools/stanley_bench_plane/ for great info.
-- NorthWoodsMan
Alonso
#2 posted 01-12-2010 08:22 PM
I don’t think I can really use that information since there’s no Stanley marks other than the Lever Cap, and that its easy to switch it from another plane but hey, there’s a lot of good information. What I see on this plane is this.
1) No brass screws for the knob of tote.
2) No screw adjuster behind the frog (last picture)
3) Cap iron is not the same width as the blade (picture no 8)
4) Lateral adjustment lever is not typical for stanley (at least not on the ones that I already own) (picture 9)
Today or tomorrow I should receive another Stanley No 5 corrugated I will compare them both and see what I can find
View RealtorJim's profile
RealtorJim
29 posts in 2989 days
#3 posted 01-12-2010 08:49 PM
The body appears to be an Ohio Tool Company Plane.
-- "If you can't find it, build it. If you can't build it, then you must need some more tools."
View CaseMan's profile
CaseMan
17 posts in 3002 days
#4 posted 01-12-2010 11:01 PM
Can’t tell you if it is a Stanley or a Franken-plane. These might help:
http://primeshop.com/access/woodwork/stanleyplane/pftsynch.htm
http://home.comcast.net/~rexmill/planes101/typing/typing.htm
For a user: Regardless of who made it, it’s worth keeping if it makes nice shavings and does it’s job.
For a collector: If you can’t identify it, resell it as a user (but don’t advertise it as a Stanley).
-- - CaseMan -
View MrHudon's profile
MrHudon
114 posts in 3087 days
#5 posted 01-13-2010 02:51 AM
The 5 on a Stanley would be on the other end of the plane and it would be “No 5”, not “No 05”
Bailey would be in the front. More then likely not a Stanley, sorry I can’t tell who did make it.
If you bought it to use and it works, why not use it?
-- Mark, www.mrhudon.com
View WayneC's profile
WayneC
13751 posts in 3974 days
#6 posted 01-13-2010 06:14 AM
The main concern I would have from a user perspective is if the Frog is not able to mate with body of the plane correctly. The parts look to be of reasonable quality. Though it definately is a Frakenplane. Any chance the tote mod is to accomidate someone with large hands?
I agree with caseman, sharpen it up and try it out. Make your decision from there.
View mvflaim's profile
mvflaim
187 posts in 2968 days
#7 posted 01-13-2010 06:35 AM
That is no question an Ohio Tool Co No 5 with a Stanley lever cap. Put an edge on it and use it.
-- http://mvflaim.wordpress.com/
WayneC
#8 posted 01-13-2010 06:47 AM
Does the Ohio frog normally have the small gaps between the frog and the bed?
WayneC
#9 posted 01-13-2010 07:11 AM
It very well may have the gap.
Here is an ohio #5 on ebay
http://cgi.ebay.com/OHIO-TOOL-CO-NO-05-WOOD-PLANE-CORRUGATED-BOTTOM-TOOL_W0QQitemZ150404902844QQcmdZViewItemQQptZLH_DefaultDomain_0?hash=item2304d4afbc
I also found another photo showing the gap between the frog and body of the plane. I am in agreement with MVflamim.
Alonso
#10 posted 01-13-2010 07:14 AM
Let me ask something,
Excuse my ignorance but what do you mean by ”Frakenplane”
WayneC
I will take a couple more of pictures of the frog area, when I was putting it back together it gave me a little bit of hard time to do it, perhaps like you said is not sitting totally flat
By the way I got my Stanley Bailey No 5 “genuine” :0 today and this one is not even close to be like the one I got today, which seems to be pretty old like a type 5~7 which make it about 123 to 110 years old !!!!! I’ll post some pics later on.
Alonso
#11 posted 01-13-2010 07:17 AM
Wayne, the main body of that one seems pretty similar to mine, if not the same one.
WayneC
#12 posted 01-13-2010 07:21 AM
I do think the only things that are out of place are the lever cap and the tote. Think the tote is a stanley tote. Assumes this is an Ohio Tool company #5.
Frankenplane is slang for a plane some one constructed of spare parts they had lieing around in their shop.
Alonso
#13 posted 01-13-2010 07:36 AM
Got it …. thanks
Alonso
#14 posted 01-13-2010 08:18 AM
Ok so here it is the picture of the frog from different angles…
You can see on this last picture that there’s some gap between the frog and the main casting…
And a couple of pictures of the tote, I’m still thinking this is not an stanley….. any other guess
I think after all I will keep it, if I don’t use it I will at least look nice on the wall… lol
mvflaim
#15 posted 01-13-2010 05:22 PM
Looks like someone drove a dowel down the long tote hole then drill a smaller diameter hole for the screw they were using. If you’re wondering what the tool is worth, it’s worth what you paid for it. It also appears to be repainted so collectors will be turned off by that along with the other things that are not original. Should be a nice user though.
