| Forum topic by Mike Shea | posted 753 days ago | 608 views | 0 times favorited | 20 replies | ![]() |
753 days ago |
well i havnt been on this site in quite some time. i have been busy busy busy. not a bad thing right? well anyways i had a chance to pick up a vintage band saw from an anonomys owner. i got there and it was a 2 ton hunk of steel covered in rust. however it ran great. it had plenty of resaw capacity and a huge throat. so i loaded it and brought it home. now heres the dilema i did some research last night and come to find that it is a “Hobart, Cleveland Kleen Kut” for all you tool people i want to know if it is worth restoring into a resawing bandsaw. have you ever heard of this. oh and the infeed is from the right side, odd isnt it. but i am seeing more pros than cons. like the fact that it accepts a 1 1/4” blade. any help from the tool junkies would be great. thanx guys -- i can do all things through christ who strengthens me |
753 days ago |
I’ll take your first test sirloins! Lol…Seems to me that even a meat cutting saw needs a tiltable wheel for blade tracking adjustment. Maybe without too much trouble you can get some good roller bearing guides on it and be in business. -- miles125, Alabama.."Architecture is frozen music"" |
753 days ago |
haha yea sirloin it is, haha. it does have a tilt wheel adjustment up top for blade tracking udjustment im sorry i diddnt mension that. i think i might just restore it ha. what can i loose. it was only 50 bucks. the 2 tons of steel is worth more than that. ill post a picture in a bit. -- i can do all things through christ who strengthens me |
753 days ago |
In my neck of the woods, you could restore and sell that. Lots of hunters doing their own butchering up here. Welcome back, btw. -- You can discover more about a person in an hour of play than in a year of conversation. (Plato) |
753 days ago |
Fire up the barby and breakout the venison!! If you check you might be able to find a wood working table for that saw. -- Thos. Angle |
753 days ago |
Mike you can borrow the “Wood Only” sign from Thos. Angle’s big green machine. 1 1/4 blade ought to be a dandy for resaw. Or for bookmatched pork chops. -- "Bordnerizing" perfectly good lumber for over a decade. |
752 days ago |
ha ha ha you guys are funny with the meat cutting jokes. all in all i disasembled it last night and found that all basic components are exactly like a wood band saw. only diference is blade RPM its really slow for that extra thick sirloin i guese, but with a change in the drive pullys she will be runnining quik enough for most cuts in wood. the size of this thing is massive its unbelievable how much it ways and every single part is CAST IRON or STELL. so ill replace pullys, tires, and blade. everything else is covered in what looked like grease but turned out to be animal fat. ha. ill clean that up and paint it and ill have a 2 ton, right side infeed, resawing band saw. ha. how about that gentelmen. thanx for all your help and jokes. i apreciate it. nice to see you guys again and ill post a picture in a bit. PEACE -- i can do all things through christ who strengthens me |
752 days ago |
I cut meat for over 20 years for a local supermarket chain. I haven’t done that in about 12 years and hadn’t had stiches in almost 13 years now…. I owned a meat cutting band saw long before I got a woodworking band saw. It took me a while to get used to the blade facing the oppisite direction that I was used to. The reason most meat cutting bandsaws (they do make a few facing the other way) is because most meat cutting is done with a sliding table and the meat cutter standing perpendicular to the wheels and most people are right handed. I don’t see why a meat saw would cut wood. Bones are a lot harder that wood. |
752 days ago |
That should have been “wouldn’t” cut wood. The only other issue I can see is that it would have a sliding table and it will not tilt for angle cuts. Joe |
752 days ago |
well thanx joe. so you used to cut meat hu? what got you into woodworking? -- i can do all things through christ who strengthens me |
752 days ago |
Mike Just remember that you have to get a different bandsaw blade. You need the teeth on the other side of the blade. -- What happens in the workshop stays in the workshop. No wait that doesn't sound right. Karson Southern Delaware karson_morrison@bigfoot.com † |
752 days ago |
o sh!t i didnt even think about that. or cant you turn it iside out? or wait flip it around, no?? no no it shouldnt matter. right? -- i can do all things through christ who strengthens me |
752 days ago |
good point im still thinking -- i can do all things through christ who strengthens me |
752 days ago |
You are right. Some people put blades on upside down, and you turn the blade inside out and it changes direction. Good catch. LOL -- What happens in the workshop stays in the workshop. No wait that doesn't sound right. Karson Southern Delaware karson_morrison@bigfoot.com † |
752 days ago |
By the way have you ever seen blades with teeth on both sides. They are usually used in very big bandsaw lumber mills. The wood can be cut going each direction in the mill. -- What happens in the workshop stays in the workshop. No wait that doesn't sound right. Karson Southern Delaware karson_morrison@bigfoot.com † |
751 days ago |
no i never heard that before. interesting tho. wouldnt the teeth on the back side of the blade eat away at blade guides and bearings? -- i can do all things through christ who strengthens me |
751 days ago |
I have this neighbor (the hippie) who is a pro-carver and has used a 2 ton meat cutter for years. He likes it. -- Bob Vila would be so proud of you! |
751 days ago |
Mike the blade is 6” or so wide so I assume that there are no back bearings. The blade must be held in a track around the wheels to keep it from moving off the wheels. -- What happens in the workshop stays in the workshop. No wait that doesn't sound right. Karson Southern Delaware karson_morrison@bigfoot.com † |
751 days ago |
I like Doug’s suggestion of doing the book matched pork chops. Never even thought of that… ;^D -- Tom, Surfside Beach, SC - Romans 8:28 |
751 days ago |
Tom, that’s essentially what a butterfly porkchop is with a thin section of flesh holding the bookmatch together. They fold it open and pound it flat. -- "Bordnerizing" perfectly good lumber for over a decade. |
750 days ago |
Bring it to the L.J. picnic. I’ll bring a cow. -- Check out my new website! http://www.blakeweberwoodworking.com |
| Forum | Topics |
Woodworking Skill Share
2919 |
3945 |
256 |
950 |
224 |
Woodworking Trade & Swap
619 |
Coffee Lounge
2390 |
LumberJocks.com Site Feedback
524 |
