Makita 2030N Planer-Joiner For Sale
Forum topic by KBuff posted 12-18-2015 04:17 AM 2707 views 0 times favorited 4 replies Add to Favorites Watch
View KBuff's profile
KBuff
3 posts in 1069 days
12-18-2015 04:17 AM
Makita 2030N Planer-Joiner, 320 mm for sale.
Light surface rust on the deck.
Original knives plus two replacement sets.
Feeder rollers need to be resurfaced.
$600.00
Grovetown, GA
View MrUnix's profile
MrUnix
7008 posts in 2376 days
#1 posted 12-18-2015 05:03 AM
Pictures would help… but I found it on CL:
Those are fantastic machines (I have two… but dual post 2030’s, not the 4 post 2030N) and built like a tank (and weigh in at right around 300lbs). They also have about the easiest to set knives on the planet – only requiring two hardwood blocks. Considered finish planers, they won’t hog off a lot of wood, but leave a baby butt smooth finish – and when properly setup, have no snipe issues at all. Particularly good for those with space constraints. And since they have independent heads for the jointer and planer, you can seamlessly run a piece of stock through the jointer, then turn around and run it through the planer without any need to switch over functions or make any adjustments. But honestly, $600 is IMO a bit steep considering the condition and needing to have the rollers recovered.
KBuff
#2 posted 12-18-2015 09:19 PM
Price is negotiable. I will consider reasonable offers.
KBuff
#3 posted 12-22-2015 11:16 PM
SOLD!
View wannabehandyman's profile
wannabehandyman
3 posts in 499 days
#4 posted 07-09-2017 01:20 AM
KBuff, I know this is an old post, but where did you get the base for the unit?
