Pattern routing with dish carving bit
Forum topic by villanut posted 12-17-2015 11:23 PM 702 views 0 times favorited 8 replies Add to Favorites Watch
View villanut's profile
villanut
12 posts in 1527 days
12-17-2015 11:23 PM
Topic tags/keywords: template routing dish carving question router
I have a new dish carving bit (1/2” shank, 1” diameter, 5/8” cutting length and NO bearing). I have only ever done pattern routing using a bearing. I was under the impression that I would use this bit in conjunction with a bushing, but I cannot find a bushing with an inside diameter large enough to handle a 1” diameter bit. I’ve looked into trying to find a bearing with a 1/2” inside diameter and a 1” outside diameter to put on the bit and secure with a stop collar, but I can’t find one. Any suggestions/options?
8 replies so far
View conifur's profile
conifur
955 posts in 1386 days
#1 posted 12-18-2015 12:06 AM
Why make a silk purse from a sows ear??? By the time you get the bushing, if you can, and some type of bearing set up, which may extend the bit too far out of the collet, just buy a straight pattern bit with either an upper or lower bearing, which ever works on your set up.
View Festus56's profile
Festus56
3524 posts in 1462 days
#2 posted 12-18-2015 12:16 AM
Here is an Amazon link to a Whiteside 1.25” bearing and stop collar that I got . They have all sizes and they are good bearings. Works well for me.
http://www.amazon.com/gp/product/B0012JI6YA?psc=1&redirect=true&ref_=oh_aui_detailpage_o03_s00
http://www.amazon.com/gp/product/B0012JEZAE?psc=1&redirect=true&ref_=oh_aui_detailpage_o03_s00
-- Mark -- Really we're not crazy, just "Limited Editions" -- http://www.jmh-limited-editions.com/home.html --
conifur
#3 posted 12-18-2015 12:20 AM
Festus56
#4 posted 12-18-2015 12:44 AM
He was looking for a bearing for a bowl bit with rounded corners as I read his post.
villanut
#5 posted 12-18-2015 02:37 AM
- Festus56
Yes … thank you for actually reading my post
conifur
#6 posted 12-18-2015 03:36 AM
My bad, though he wanted to use that bit with a bearing addition for pattern making.
View jerryminer's profile
jerryminer
944 posts in 1676 days
#7 posted 12-18-2015 05:03 AM
Infinity has bearings with 1/2” ID and OD’s of 1”, 1 1/8”, 1 1/4” and more:
Bearings
villanut
#8 posted 12-18-2015 05:35 AM
Infinity has bearings with 1/2” ID and OD s of 1”, 1 1/8”, 1 1/4” and more:
Bearings
- jerryminer
Thanks! I can’t believe this is such an uncommon size.
