Maloof Joint General Question
« back to Joinery forum
Forum topic by BenjaminDaniels posted 12-17-2015 12:05 AM 1016 views 0 times favorited 5 replies Add to Favorites Watch
View BenjaminDaniels's profile
BenjaminDaniels
4 posts in 780 days
12-17-2015 12:05 AM
Topic tags/keywords: question maloof joinery
Ok guys and girls,
So I’m semi-new to woodworking and I want to try to make a small side table that utilizes the Sam Maloof joint. My question has to do with the router bits used in the joint; do the round over and rabbet bits simply have to have the same diameter in order to come together properly? Would bearing size matter as well? I’m confused! Thanks so much for the help.
All the best,
Ben
5 replies so far
View Dave G's profile
Dave G
329 posts in 1924 days
#1 posted 12-17-2015 04:25 AM
I’ve made a few chairs with that joint. You use the rabbet bit to cut a relief in the top and bottom in the flat board. Where it stops it leaves a corner radius. The flat board has to be really thick to do this and still have a normal joint underneath these roundover cuts. Then you use the matching roundover bit on the corners of the legs so the legs will slip into the rabbet.
The legs need to be thick, like the flat boards, because you do a ton of smoothing, forcing round tools right into the crease of that joint.
I can take some pictures tomorrow if you still need help. It seems like it is hard to visualize from a few words.
-- Dave, New England - “We are made to persist. that's how we find out who we are.” ― Tobias Wolff
View MNgary's profile
MNgary
296 posts in 2293 days
#2 posted 12-17-2015 05:52 AM
I would like to reply but the site insists on placing an advertisement in the middle of my replyl
-- I dream of the world where a duck can cross the road and no one asks why.
Dave G
#3 posted 12-18-2015 12:50 AM
Yes they must both be identical size. My set is 3/4 inch RADIUS roundover paired with 3/4” RADIUS rabbet. Tools cut RADII so that’s what has to be the same if the cut surfaces are to match exactly. A 3/4” internal radius matches a 3/4” external radius surface perfectly. Does that make sense and help you remember?
BenjaminDaniels
4 posts in 780 days
#4 posted 12-18-2015 01:30 AM
I think it’s making sense now! I’m trying it tomorrow on some junk pine I’ve got laying around the shop so we’ll see how it goes! Thanks everyone!
View bearkatwood's profile
bearkatwood
1453 posts in 888 days
#5 posted 12-18-2015 03:08 AM
I use the whiteside bits, but if you have a 1” wide dado bit with a 1/2” bearing and a 1/2” roundover bit you can have good success. For my angled cuts I use a shop made jig that holds the router at an angle. I will add it to the possible videos I plan on making. Hope this helps.
-- Brian Noel
