Seconds Please
Forum topic by Dchip posted 1225 days ago 623 views 0 times favorited 7 replies Add to Favorites Watch
View Dchip's profile
Dchip
265 posts in 1420 days
1225 days ago
Topic tags/keywords: question
Deviating slightly from the usual tool-buying advise, I was curious as to what people would say is the most beneficial power tool to have 2 of. I have recently acquired most of the basic tools needed in a full workshop, so of course I’ve started looking for seconds. The first two that come to mind are a second drill/driver or router, though I’ve heard people sing the praises of such things as two table saws, etc. Any input is appreciated.
-- Dan Chiappetta, NYC, http://www.9x7woodworks.com
7 replies so far
View magicman's profile
magicman
164 posts in 1777 days
#1 posted 1225 days ago
I would agree that having two drills is very helpful. I have four hand sanders that I put different grits of sandpaper on, that way I don’t have to keep changing the paper so many times.
-- Twenty years from now you will be more disappointed by the things that you didin't do then by the ones you did. - Mark Twain
14855 posts in 2386 days
#2 posted 1225 days ago
Drill would rank high, but I think I’d go with router as my number one… particularly if you use a router table. Being able to leave one in the table and have another for hand-held work is a huge time saver.
View Don Newton's profile
Don Newton
711 posts in 1786 days
#3 posted 1225 days ago
Router
-- Don, Pittsburgh
View Fireguy's profile
Fireguy
132 posts in 1403 days
#4 posted 1225 days ago
Router. I have one, wish to add another.
-- Alex
View 8iowa's profile
8iowa
1442 posts in 1929 days
#5 posted 1225 days ago
Having two shops, one in Gainesville, Florida, and another in the Upper Peninsula of Michigan, I have had to do a heck of a lot of duplication. Hauling tools and accessories back and forth 1420 miles is just not efficient. I’m trying to keep notes on what I have at both places, but even this is a little hard to keep track of. The shop in Michigan is bigger, (600 sq. ft.) and for awhile I had three Shopsmiths up there with duplcate bandsaws and jointers. That was a little “over the top”, so I gave a Shopsmith, bandsaw, and jointer to my two nephews out in Denver to help them get started in woodworking.
Strangely enough, I even sorta duplicate wood. On trips back and forth I often stop at the Frank Miller Lumber Company and purchase a selection of hardwoods, and depending on the direction I’m heading, take the wood North or South. That reminds me, I need some more walnut up in Michigan.
View Kent Shepherd's profile
Kent Shepherd
2690 posts in 1454 days
#6 posted 1225 days ago
I have 2 table saws in my home shop. While it is nice, it certainly would not be a priority for me. I just happened to have one that was my dads, besides my new one, which is bigger, better, and newer. Unless you have a lot of floor space, it probably wouldn’t be worth the room you would lose.
I would look at getting more routers—-I have 7, and use them all
Extra drill drivers might also be a good choice, especially different sizes
I would also consider an impact driver—much better fo screws
View Ger21's profile
Ger21
594 posts in 1299 days
#7 posted 1225 days ago
Routers. I have two mounted in plates that I use both in a table, as well as for handheld use. A PC 690, and a 7518. I also have a 690 plunge router, and two laminate trimmers. One laminate trimmer usually has a small roundover bit that get’s used all the time,
-- Gerry, http://home.comcast.net/~cncwoodworker/CNC_Woodworker.html
