Best double sided tape for use in a planer?
Forum topic by Lloyd Davies posted 01-11-2010 10:09 AM 3347 views 0 times favorited 7 replies Add to Favorites Watch
View Lloyd Davies's profile
Lloyd Davies
116 posts in 3349 days
01-11-2010 10:09 AM
Topic tags/keywords: resource question planer bent lamination laminate lamination
I am have cut with a band saw some pieces of walnut that are 12” by 6” and about 1/4” thick. Once side of each piece is flat; the other has band saw marks. When I am done I am going to bend and laminate the pieces. I don’t own a thickness sander so was thinking of taping the walnut pieces to a thicker pieces of scrap wood and putting them through my thickness planer. So the planer would think it is planing a 12” x 6” x 1” solid piece of wood.
Any thoughts on the best type of double sided tape to use for this?
-- Northern California http://www.lloydus.com
7 replies so far
27250 posts in 3845 days
#1 posted 01-11-2010 03:08 PM
Lloyd, one thing you might want to consider is sanding the board by hand. Bascially this consists of making a jig from mdf and putting a couple of dowels in it for handles. Attach some self-adhesive sandpaper to the underside of the jig and you can thickness sand small pieces by hand.
View rhett's profile
rhett
742 posts in 3690 days
#2 posted 01-11-2010 03:12 PM
Carpet tape. Also, a small cleat at the end of a sled will help hold the thinner stock in place. The force will be mainly lateral in this application.
-- Doubt kills more dreams than failure.
View syenefarmer's profile
syenefarmer
492 posts in 3103 days
#3 posted 01-11-2010 04:25 PM
I use this double sided tape, It’s fairly thin but easy to work with and the price is very reasonable.
Lloyd Davies
#4 posted 01-11-2010 08:37 PM
Thank you all.
Scott I am having a hard time imagining the jig you talk about and how it works. Is it able to make the piece flat, AND parallel, like a planer might?
View Raspar's profile
Raspar
246 posts in 3171 days
#5 posted 01-11-2010 08:58 PM
I use the left over rolls of tape from the window kits I get. Is very strong although I have never put it through a planer. Just another idea.
-- Have thy tools ready. God will find thee work.
#6 posted 01-12-2010 12:56 AM
Lloyd, this was a e-mail tip that Wood Magazine sent out recently. I did not save it but essentially it is like the following:
Self adhesive sandpaper is attached to the bottom of the block and the thin blank of wood is carpet taped to a flat surface. I remembered it seemed to be built similar to my planer push block:
without the shoe of course.
Hope this helps.
View papadan's profile
papadan
3584 posts in 3391 days
#7 posted 01-12-2010 01:45 AM
Don’t try the planer 12×6x 1 is even too small to safely put through the planer. Use a random orbit sander to flatten your pieces now. Next time, resaw and run through the planer before cutting so short. Your only chance is to mount the pieces on a longer board and keep them tight together. I use turners tape to attach wood to other pieces, it holds bowl blanks while roughing them, so it should hold these pieces.
