Milling Aromatic Red Cedar
Forum topic by SteveInVa posted 12-15-2015 11:03 PM 1076 views 0 times favorited 24 replies Add to Favorites Watch
View SteveInVa's profile
SteveInVa
29 posts in 1983 days
12-15-2015 11:03 PM
I am making a cedar closet as part of a larger set of cabinets and laundry bins. I am going to line the closet with T&G aromatic red cedar but am thinking of picking up some rough sawn 4/4 ARC from the local lumber yard and milling my own shelves and cove molding. Each shelf will be 2 feet wide and 20 inches deep. So, I would have to cut the 8 foot boards into two foot lengths, plane them down to desired thickness (probably 3/4”) and then plate join three of those 2-foot lengths to form a shelf 21 inches deep. I will make 5 or 6 shelves of this size (the closet is 84 inches high)
I have heard that milling ARC can be a challenge and that it can really wear out planer knives, and I am seeking your advice and wisdom on what to watch out for as I plane and cut these boards? What should I beware of before embarking on this phase of the project? Or am I better off buying 1/2 thick ARC plywood (available from Home Depot online only) and eat the extra cost but be assured of uniformly even and level shelves and just mill the little that I need for cove molding and edgebanding?
Thanks in advance for any advice.
-- Steve
24 replies so far
View toddbeaulieu's profile
toddbeaulieu
814 posts in 3031 days
#1 posted 12-15-2015 11:10 PM
Milling cedar is hard on knives? Geeze, I never heard that. I’ve milled plenty of eastern, but probably not aromatic. I’ve worked with aromatic closet lining and found it to be every bit as soft. Is there something I’m missing, like abrasives or something?
First, I’d always mill them longer and THEN cut them to avoid snipe and eliminate potentially ruining a piece because of the end.
If it were me, I’d check out what’s in stock for 4S and if it’s suitable to the project and flat and straight, I’d consider it because RS is still a lot of work to mill and you have to deal with waste, varying depending on the stock you end up. I enjoy RS milling and prefer that to have total control, rarely going with 4S, BUTTTTTT … I’ve also had a lot of second thought specifically about cedar because of the work involved in getting around knots and branches in the RS.
Not sure that I helped, but just my thoughts.
View bigblockyeti's profile
bigblockyeti
5140 posts in 1747 days
#2 posted 12-15-2015 11:14 PM
I’ve planed quite a bit of aromatic cedar and didn’t notice any accelerated wear on my knives. It’s soft enough that it didn’t prove to be too taxing on the planer either despite having knives that while still sharp, certainly weren’t brand new.
SteveInVa
#3 posted 12-15-2015 11:14 PM
Thanks for the quick reply, Todd. The lumber at the mill would be RS, not 4S. So, I would have to work around knots and the like. And like you, I enjoy milling RS. And good advice to cut them long to avoid the snipe.
-- Steve
View conifur's profile
conifur
955 posts in 1178 days
#4 posted 12-15-2015 11:45 PM
Aromatic Cedar, be sure to wear a mask, and even the dust on skin can be very irritating.
View gfadvm's profile
gfadvm
14940 posts in 2717 days
#5 posted 12-16-2015 01:48 AM
ARS (Eastern Red Cedar) is very soft BUT the knots can be hard and tend to chip out or come out completely and bang around inside your planer.
View Jim Finn's profile
Jim Finn
2658 posts in 2949 days
#6 posted 12-16-2015 02:21 AM
I plane about 450 board feet of rough eastern red (aromatic) cedar every year now for six years. I re-saw it to 1/2” and plane to 3/8”. That works out to over 700 lineal feet of planning each year. The only issue to watch for are knots coming loose and rattling around inside of the planer. Damage to the planer like this has happened to me often. I get cedar pretty cheaply (less than $2 a BF) but buying the already milled stuff may be worth the cost.
-- Website is No PHD just a DD214 and a GED https://craftingcouple.com/
View nick_name's profile
nick_name
17 posts in 992 days
#7 posted 12-16-2015 06:04 AM
it will make your dust collector smell fantastic for about 6 weeks. No issue on planer knives.
View rwe2156's profile
rwe2156
2965 posts in 1508 days
#8 posted 12-16-2015 12:37 PM
I’ve planed a ton of it. It is a very soft wood the only wear factor are the knots. Jim is correct if a knot ever comes loose you’ll know it real quick. Can be especially dangerous when ripping on the TS it can be a heart stopper.
Bottom line: Pays to check the knots before planing or sawing ;-)
BUT – DO worry about the dust, especially when table saw or sanding. It’s kind of like MDF it goes every where and gets on everything.
Cedar dust can be extremely irritating to the lungs so make sure you wear a full face respirator (not a cheap paper dust mask) and blow all your clothes off before going back in the house.
View LiveEdge's profile
LiveEdge
586 posts in 1647 days
#9 posted 12-16-2015 10:26 PM
I may be wrong, but the occupational dust risks are mainly with Western Red Cedar (unrelated to Eastern Red Cedar) and their high concentration of plicatic acid. I was not under the impression that ERC has the same problem and couldn’t find too much info to the contrary.
View verdesardog's profile
verdesardog
161 posts in 2638 days
#10 posted 12-16-2015 11:55 PM
A helical cutter head would be best for knotty wood like cedar….and dust protection is a good idea, cedar is known to be toxic to some and irritating to most people.
-- .. heyoka ..
conifur
#11 posted 12-17-2015 12:05 AM
LiveEdge and all, go to ARC, I mean we are all on the internet here, just doing a search can answer your own questions, or as I do verify a statement b4 I give it, or is it just laziness?????
http://www.wood-database.com/wood-articles/wood-allergies-and-toxicity/
SteveInVa
#12 posted 12-17-2015 12:06 AM
Thanks to all for these very helpful replies and advice. It looks like I should try to work around knots as best as possible and do as much of the cutting (and all of the sanding) outside to minimize the dust (though it could bring a nice aroma to the shop when finished).
I’ll post an update after I’m done milling it, but that won’t be until January, after the holidays.
-- Steve
rwe2156
#13 posted 12-17-2015 01:44 AM
I may be wrong, but the occupational dust risks are mainly with Western Red Cedar (unrelated to Eastern Red Cedar) and their high concentration of plicatic acid. I was not under the impression that ERC has the same problem and couldn t find too much info to the contrary.
- LiveEdge
It definitely puts out an obnoxious dust. To be exact, I guess I’m using southern red cedar.
Could just be me, but I have definitely has respiratory issues afterwards.
rwe2156
#14 posted 12-17-2015 01:51 AM
- conifur
I agree, but personal experience counts for something, no?
Thanks for the resource. It verified my experience!!
conifur
#15 posted 12-17-2015 01:57 AM
rew2156,
I am glad, SRC is bad too.
