Lathe Height
« back to Woodturning forum
Forum topic by paratrooper34 posted 12-15-2015 09:15 PM 926 views 0 times favorited 12 replies Add to Favorites Watch
View paratrooper34's profile
paratrooper34
915 posts in 3187 days
12-15-2015 09:15 PM
Hi All,
Well, I finally broke down and bought a power lathe (Craftsman). As averse as I am to power tools, I have a need for some turned items and figured I would just pony up and buy one as building a spring pole or other non-powered lathe would be too far off in the future to suit my immediate needs.
I am going to build a stand for the lathe and I am not sure what height it should be at for optimum use. I put the lathe on top of my bench, which stands at 36”, and that is way too high. So 30”? I don’t know. I am 5’9” (69”) tall. Any ideas for how high the lathe should be?
Thanks in advance!
-- Mike
12 replies so far
View Richard H's profile
Richard H
489 posts in 1916 days
#1 posted 12-15-2015 09:33 PM
I don’t know if there is a standard but I like my fingers to be in line with the center line of the lathe when my upper arm is resting at my side, lower arm bent 90 degrees at the elbow and hand held straight out finger tips pointed at the lathe. I find that works well for me when using traditional turning tools. I’m not sure if you would adjust that for carbide tools or not.
View OSU55's profile
OSU55
2025 posts in 2225 days
#2 posted 12-15-2015 10:03 PM
When setting mine up research suggested having the elbow equal to the spindle centerline, same as what Richard suggests. Thats how i set it up and it works well. I would not want it lower. Possibly an inch or 2 higher, but elbow height is a good starting point and after getting experience fine tune it.
View DrDirt's profile
DrDirt
4526 posts in 3978 days
#3 posted 12-15-2015 11:02 PM
I shoot for e.g. with the roughing gouge to have my anchor hand right at my belt, and my forearm holding the metal at the tool rest to be ‘horizontal” to a little lower.
Suppose that woudl work out to you being able rest your elbow on the tool rest
View JoeinGa's profile
JoeinGa
7739 posts in 2243 days
#4 posted 12-15-2015 11:05 PM
I started out with mine as Richard said. but figured out pretty quickly that I was getting a sore back from having to bend over while turning the inside of the bowls. So now mine is 2” or 3” higher than that.
View TheDane's profile
TheDane
5575 posts in 3899 days
#5 posted 12-15-2015 11:56 PM
Rule of thumb I was told: spindle should be at your elbow height.
woodbutcherbynight
5825 posts in 2645 days
#6 posted 12-16-2015 03:51 AM
And to top all those suggestions off, if you change to a bigger lathe and it is a different height you have to lower it. In my case I built a custom cabinet and bolted the lathe to it. The new lathe I have been dreaming about will require a 8” lift kit so I can reach it. (Laughing)
paratrooper34
#7 posted 12-16-2015 01:16 PM
Thanks everyone. Much appreciated.
-- Mike
View jeff's profile
jeff
1132 posts in 3700 days
#8 posted 12-16-2015 03:36 PM
Originally spindle was at elbow height for me but I added 1.5” and like it much better now.Would not want to go lower.
-- Jeff,Tucson,Az.
View jfoobar's profile
jfoobar
44 posts in 1566 days
#9 posted 12-16-2015 10:09 PM
Yet another recommendation to at least start with the spindle at elbow height and adjust from there. I would rather have it a bit too high than a bit too low.
View bob101's profile
bob101
333 posts in 3686 days
#10 posted 12-16-2015 11:38 PM
I have mine setup so that the centres are just above my waist.
-- rob, ont,canada
View Dark_Lightning's profile
Dark_Lightning
3367 posts in 3345 days
#11 posted 12-17-2015 03:02 AM
Ergonomically, the tool should be in such a position that your elbow is bent at 90°, with your upper arm vertical to the floor. That may require some adjustment based on your build, but that is how workstations for using computers are set up- everything at right angles. This keeps you body in the best position for effective and less tiring work.
-- Random Orbital Nailer
View Woodknack's profile
Woodknack
12455 posts in 2616 days
#12 posted 12-17-2015 04:57 PM
I built my last lathe stand so the spindle was at elbow height but I wouldn’t have minded a it being a couple inches higher. My current lathe has a factory stand that puts it well below elbow height and many old lathes I see in pictures are lower too but I think I will build a new stand and bring it up to elbow height then maybe use blocks under it to raise it a tad more.
