What planer to buy?
« back to Hand Tools forum
Forum topic by Thebeardedape posted 12-15-2015 05:15 PM 904 views 0 times favorited 15 replies Add to Favorites Watch
View Thebeardedape's profile
Thebeardedape
6 posts in 1067 days
12-15-2015 05:15 PM
Topic tags/keywords: planer gift
Hey there, woodworkers!
Christmas is coming up and i’m looking for a great gift for my dad. I’ve heard him talk about Lie Nielsen planers for a long time now. I called a local woodworking shop for advice, but i was not completely satisfied with the answer. The shop owner told me to either get The #4, or the low angle jack plane.
My dad mostly works on large projects, like bookshelfs. What planer gives me the most practicality for the money?
Thanks in advance!
15 replies so far
117272 posts in 3750 days
#1 posted 12-15-2015 05:22 PM
I think the shop owner had good suggestions.
Thebeardedape
#2 posted 12-15-2015 05:25 PM
Thanks for your reply,
What do you think is the better gift for allround woodworking? Unfortunately i have to choose one.
View Tim's profile
Tim
3812 posts in 2135 days
#3 posted 12-15-2015 05:35 PM
You couldn’t really go wrong with either, I agree with Jim.
The first LN plane I would buy is the #4 because that’s the plane that’s worth being tuned up the best.
View Richard H's profile
Richard H
489 posts in 1854 days
#4 posted 12-15-2015 05:35 PM
- Thebeardedape
That’s kind of a loaded question as it depends on what he is going to use it for. Both a #4 and #5 are great all around planes with the #4 being more used for smoothing and the #5 being the all around Jack of all trades plane. If you are looking for something he can use to replace sanding and finish prep in the shop I would suggest the #4. If you are looking for something he can use for early stages of finish prep plus the occasional need to do something like take a 1/32” off a board, making panels join together for glue up perfectly, or do fine finesse work on a joint it’s hard to beat the #5.
Although I would throw out a 3rd option and say if he doesn’t already have one get him a low angle block plane. I’m assuming he mostly uses power tools and a block plane fits really well into that world when you just want to tweak what comes off the power tool just a tiny bit to make it perfect without having to go back to the machine and try and adjust it for a 2nd cut.
View knotscott's profile
knotscott
8140 posts in 3549 days
#5 posted 12-15-2015 06:00 PM
Do you know what other hand planes your dad has?
Thebeardedape
#6 posted 12-15-2015 06:04 PM
Thanks to all,
To me it sounds like the #5 is the best option for my dad. In my understanding the #5 is different from the low angle jack plane which i believe is #62, what the shop owner suggested. Am i right? If so, why should i pick the #5 instead of #62?
Thebeardedape
#7 posted 12-15-2015 06:06 PM
My dad has 2 planes, all i can tell you about them is that one fits easily in a hand. The other is larger, an old english planer from stanley which he got from his dad.
Richard H
#8 posted 12-15-2015 06:24 PM
The small one is probably a block plane. I’m not sure about the other, if it’s a stanley it should have a number stamped on the toe of the plane.
A traditional bevel down plane has a fixed cutting angle determined by the angle of the frog (usually 45 degrees). A low angle bevel up plane has the angle set by the irons bevel angle plus the angle of the frog. So a 15 degree frog plus a 30 degree bevel angles gives you a 45 degree cutting angle. You can’t adjust the cutting angle of a bevel down plane without changing the frog where you can with a bevel up version by changing the irons bevel angle. Hope that makes sense.
View rwe2156's profile
rwe2156
3134 posts in 1654 days
#9 posted 12-15-2015 07:45 PM
Its a difficult question to answer without knowing what kind of ww’ing your dad does.
#5 low angle jack is a good choice if he already has a #4.
He can use it with a shooting board (get the optional hot dog handle).
I think the safest bet is a #4 smoother.
Thebeardedape
#10 posted 12-15-2015 07:56 PM
I’ve just watched a ton of videos, i think the 62 is the best choice. It’s seems to be the most versatile plane to have. For rough and precise work. So this might be a great starter plane.
My dad likes to make furniture i believe.
knotscott
#11 posted 12-15-2015 08:16 PM
A jack plane is pretty useful for a lot of things, so it’s usually a safe choice.
Thebeardedape
#12 posted 12-15-2015 08:23 PM
Alright, i’ve made my choice. Thank you all !
View dday's profile
dday
165 posts in 1603 days
#13 posted 12-15-2015 08:30 PM
Interesting thread none the less, but based on the question, I was expecting to recommend a benchtop planer..
View Don W's profile
Don W
18988 posts in 2741 days
#14 posted 12-16-2015 12:06 AM
I have a LN #62. Its one of my least used planes. If you plan to use planes, you’ll need more than 1 or 2. I always suggest starting with a #4. Its a smoother. Most of the time a beginner just wants to smooth.
View OSU55's profile
OSU55
1924 posts in 2163 days
#15 posted 12-17-2015 03:56 AM
You might look at a Lee Valley Veritas Low Angle Bevel Up Jack plane I prefer it to my brother’s LN version. There are several reviews on LJs
