How would you cut this pattern? Router table and Drill Press
Forum topic by onesojourner posted 12-15-2015 02:41 PM 1580 views 0 times favorited 23 replies Add to Favorites Watch
View onesojourner's profile
onesojourner
73 posts in 1590 days
12-15-2015 02:41 PM
I am needing to cut this pattern in a 7.5 inch block. Does any one have any tips on the best way to do this? I have a router table and a small drill press. The line will be 1/8” and the circles will be about 1/2”
-- http://icftfsystemshome.blogspot.com/
23 replies so far
View bondogaposis's profile
bondogaposis
4529 posts in 2225 days
#1 posted 12-15-2015 03:35 PM
Drill press for the holes, router w/ an edge guide for the lines.
-- Bondo Gaposis
View Richard H's profile
Richard H
489 posts in 1555 days
#2 posted 12-15-2015 03:42 PM
As Bondo said if you drill the holes first you have a place to start and stop your router bit and can use a edge guide to get straight lines. You could also do it on a router table with fence but you will be plunging the bit in blind at the start and stop holes. It shouldn’t be that hard and might be faster since you don’t have to worry about moving the piece around and readjusting your hold downs but me personally I think I would just use a straight edge as I like to see my work whenever possible.
Or you could buy a CNC machine and program that to do it really fast if you want a excuse to buy a new expensive tool :-).
View ThomasChippendale's profile
ThomasChippendale
244 posts in 806 days
#3 posted 12-15-2015 03:46 PM
BYW to cut this patern with 1/2 inch holes will require a 12 X 12 inches surface. How deep is the cut to be?
-- PJ
onesojourner
#4 posted 12-15-2015 04:07 PM
- ThomasChippendale
I am sure I will need to compress the pattern a bit to make it work.
View Kaleb the Swede's profile
Kaleb the Swede
1800 posts in 1843 days
#5 posted 12-15-2015 04:10 PM
Are they through the wood completely? If so you could scroll saw it carefully too, if you have one. If I am way off mark (which I am many times) please disregard this comment
-- Just trying to build something beautiful
onesojourner
#6 posted 12-15-2015 04:30 PM
Nope this will just be very shallow, maybe an 1/8” or so.
onesojourner
#7 posted 12-15-2015 04:30 PM
View pintodeluxe's profile
pintodeluxe
5544 posts in 2687 days
#8 posted 12-15-2015 04:44 PM
I would be tempted to make a little scratch stock with adjustable fence. However I might just cut it with a compact router and edge guide.
onesojourner
#9 posted 12-15-2015 04:50 PM
- pintodeluxe
I am not sure what that is. Can you explain or link to an example?
View Kazooman's profile
Kazooman
914 posts in 1826 days
#10 posted 12-15-2015 04:51 PM
If this is a one off, I agree with using an edge guide for the router for the lines. I assume that this is some sort of game board and you might be making several of them. If so, you could prepare a series of templates to use with a router with a guide bushing. Three with square holes that would align the bit on the centers of the holes that form the squares and one with four slots of the cross connecting lines. Drill the holes first and then use the templates. They could have strips on the bottom that index them with the edge of the block to hold them in alignment.
View jbay's profile
jbay
1933 posts in 773 days
#11 posted 12-15-2015 05:04 PM
I’m curious why you don’t use a table saw to cut them?
Edit:
Nevermind, I guess the cuts would run through on the ends
-- If anyone would like to see my Portfolio, PM me and I would be glad to send you the link.
View waho6o9's profile
waho6o9
8070 posts in 2451 days
#12 posted 12-15-2015 05:05 PM
Bondos’ idea works well too.
A router and a guide rail is a worthwhile investment.
onesojourner
#13 posted 12-15-2015 05:07 PM
I kind of like that idea. I will have to think how I could do that. I have been thinking about 3 layers (roughly 1 inch thick) that would ride/act as the fence and I Would remove one for each smaller section. That would not address keeping the holes aligned with the the lines though.
This is a one off, but if I can get this process streamlined I may produce several.
116811 posts in 3451 days
#14 posted 12-15-2015 05:10 PM
Since this is 7.5 ” thick the best approach I can come up with is,if you need the holes drill them first on the drill press then band saw all the lines and glue back together,after the glue drys redrill the holes to get rid of any distortion the band sawing and glue might have made.
onesojourner
#15 posted 12-15-2015 05:16 PM
- a1Jim
The block is about 3 inches thick and there will be no through cuts.
