Cleaning out blank tubes
Forum topic by yellowtruck75 posted 01-10-2010 04:56 PM 1017 views 0 times favorited 7 replies Add to Favorites Watch
View yellowtruck75's profile
yellowtruck75
469 posts in 3307 days
01-10-2010 04:56 PM
I am having trouble when it comes to cleaning out the tubes of my blanks after glueing. When I prep my blank I use thick CA glue to glue the tube in. When I put the tube in I twist to distribute the glue and then I let it dry over night. When I come back the next day to clean out the excess glue the tube continues to be pushed out. Sometimes I am able to get the bit through to ge the glue but when trueing the ends up the tube pops out. What am I doin wrong that it causing this? Its becoming a real pain to continuely reglueing.
Thanks
7 replies so far
View Roper's profile
Roper
1389 posts in 3953 days
#1 posted 01-10-2010 05:14 PM
i use some sandpaper and scratch up the tubes before i glue them in, this works for me. it gives the glue something to stick to.
-- Roper - Master of sawdust- www.roperwoodturning.com
View airman's profile
airman
51 posts in 3456 days
#2 posted 01-10-2010 07:28 PM
Heat breaks down the chemical bond between the tube and the wood. Try using a different type of glue
View interpim's profile
interpim
1170 posts in 3698 days
#3 posted 01-10-2010 07:39 PM
I’ve had that happen a few times, and it usually is due to overheating the tubes… try to slow down your drill press to keep from heating it up.
Also, scratching the tubes up with coarse sandpaper is advised, and on oily woods try using epoxy instead of CA.
-- San Diego, CA
View rickf16's profile
rickf16
392 posts in 3821 days
#4 posted 01-10-2010 08:33 PM
Try using medium CA. Also, are you using an accelerator? I scratch the tubes with 120, put a ring of glue on the inside end of the blank that receives the tube, liberal coating of glue on the tube, twist while inserting to insure complete coverage, then hit both ends with the accelerator. Wait about 5 minutes, cut the excess on the table saw and square up the blanks with a barrel trimmer. This works for me.
-- Rick
View bill1352's profile
bill1352
130 posts in 3362 days
#5 posted 01-11-2010 05:06 AM
i use a small round rasp to clean out my tubes before i use the barrel trimmer. i’ve also went to epoxy. if your letting it sit overnight a 15 min epoxy gives you more time, fills any gaps better and is very strong. i give it an hour after glue up without a problem.
-- Keep Your Stick On The Ice
View JTTHECLOCKMAN's profile
JTTHECLOCKMAN
232 posts in 3390 days
#6 posted 01-11-2010 06:21 AM
Play dough is your friend. No don’t take the kids, go get your own. Take a glob of play dough and flatten. no take the tube and stick it in the play dough and twist abit when you pull it out. You now seal the ends so no glue gets inside. After the blank is dry just push the playdough out and use the mill. I too have used epoxy and have never had a failure.
-- John T.
View jayman7's profile
jayman7
218 posts in 3745 days
#7 posted 01-11-2010 02:30 PM
Ditto on what Rick said. Try letting the blanks cool down for a while after the drill press before you insert the tubes.
