Difference between Ryobi and Makita belt sander.
Forum topic by MAC_addy posted 12-14-2015 09:36 PM 989 views 0 times favorited 14 replies Add to Favorites Watch
View MAC_addy's profile
MAC_addy
9 posts in 799 days
12-14-2015 09:36 PM
Good morning all!
So I’m looking at purchasing a belt sander. I need it to remove quite a bit of material from the front of a drawer face. I was wondering, what’s the major difference between the Ryobi line and the Makita line? Other than cost, is there really much a difference between the two?
Thanks!
14 replies so far
View MrUnix's profile
MrUnix
6346 posts in 2103 days
#1 posted 12-14-2015 09:49 PM
Yes. Ryobi is cheap for a reason.
View AZWoody's profile
AZWoody
1263 posts in 1128 days
#2 posted 12-14-2015 09:54 PM
- MrUnix
Ryobi tools haven’t been that bad in my experience. I’ve had a drill and an impact driver that has never given me a problem and then I decided to upgrade to a Makita set and both the drill and impact broke and had to be sent in for repairs.
Ryobi’s weakness in their battery tools, in my opinion have been the batteries. They go bad fast and I’ve had to replace them quite a bit.
View dhazelton's profile
dhazelton
2687 posts in 2201 days
#3 posted 12-14-2015 10:18 PM
If that’s your only use for a belt sander then buy the cheaper one and go to town. If it dies on you return it within Home Depot’s warranty period.
Makita makes good stuff. Ryobi makes good enough stuff.
View Jim Finn's profile
Jim Finn
2619 posts in 2826 days
#4 posted 12-15-2015 03:34 AM
Are you considering a hand held belt sander or a stationary belt sander? I have had a Ryobi stationary sander and it worked well for a long time. If it is a hand held sander… I have a friend who likes the Makita because it is flat on top and he clamps it to a table up-side-down and moves the wood.
View Bill1974's profile
Bill1974
124 posts in 2890 days
#5 posted 12-16-2015 05:29 PM
I just when through the looking for a belt sander search and ended up getting a 4×24 Harbor Freight one. It’s beefy and does work well. Dust collection isn’t great but I also don’t have any other belt sander to compare it too. I chose The HF over the Ryobi because the HF is larger, more powerful, uses 4×24 belts (same as the Ridigid benchtop sander I have), it has a variable speed control and it’s a reasonably priced. I think I paid around $60 with a coupon.
Tracking is good on it, the stock belt is holding up well. Use the belt cleaner on it if it loads up, it makes a difference.
On a side note:
In my experience the Ryobi battery (18V) tools all work well and are a great value. I only use their largest battery and they last as long or longer than my Bosch and Milwaukee tools. The original Ni-Cad batteries are crap, the latest High Capacity LITHIUM+ ones are great in my opinion. The smaller lithium are ok but for the cost I go with the largest ones, you can get two for $99 plus tax.
dhazelton
#6 posted 12-16-2015 07:37 PM
“I need it to remove quite a bit of material from the front of a drawer face.”
Just reread that and wonder if using a paint scraper or stripper might serve you better than buying a tool you only need once.
Bill1974
#7 posted 12-16-2015 08:59 PM
If you have a planer I would say that might be your best bet. It will be the quickest.
View PineChopper's profile
PineChopper
187 posts in 2101 days
#8 posted 12-16-2015 10:15 PM
I had a few Ryobi tools that were just junk! I haven’t bought another one since.
I have a Makita angle grinder that I’ve been using for 30 years now.
My belt and orbital sanders are both Hitachi. They are also about 30 years old and never given me a problem.
View bob101's profile
bob101
321 posts in 3354 days
#9 posted 12-16-2015 11:35 PM
I purchased one ryobi tool and I will never buy another!
-- rob, ont,canada
View verdesardog's profile
verdesardog
154 posts in 2516 days
#10 posted 12-16-2015 11:44 PM
friends don’t let friends buy Ryobi junk….....
-- .. heyoka ..
View oldnovice's profile
oldnovice
6543 posts in 3272 days
#11 posted 12-17-2015 02:15 AM
I have two Ryobi tools, my first and my last!
View RogerM's profile
RogerM
790 posts in 2303 days
#12 posted 12-17-2015 01:51 PM
Yes, there is a difference like day and night!!!
-- Roger M, Aiken, SC
View Tom's profile
Tom
172 posts in 965 days
#13 posted 12-17-2015 05:13 PM
I have a Ryobi belt sander, needed it for a project. I’ve had no problems with it and have used it to sand a custom floor to tile transition piece and I’ve used it clamped in my vise as a stationary sander. I’m not sure buying a more expensive sander would’ve been worth the money. If it’s going to be used on a regular basis in the long run a better quality tool is the way to go.
View josephf's profile
josephf
182 posts in 2001 days
#14 posted 12-21-2015 01:11 AM
had a ryobi and bosch years back . the difference may only be in how you use it . the ryobi at that time had a plastic gear that we would break .but it was being used hard . deck jobs and hussle mentality . not cabinet work . i agree with the poster who said get the ryobi if thats all you will use it for .if you really think you will use it a lot you maybe in the market for a big 6” orbital .like festools rotex . seems to of replaced most everything i once used a belt sander for .
