straightening wood
Forum topic by dbw posted 12-12-2015 08:50 PM 982 views 0 times favorited 12 replies Add to Favorites Watch
View dbw's profile
dbw
201 posts in 1630 days
12-12-2015 08:50 PM
Topic tags/keywords: maple cupped straighten
Greetings all,
I need to know if any of y’all know of a way to PERMANENTLY straightening wood which is cupped along it’s length. The patient in question is a piece of soft maple which is 4/4 X 60” long X 8” wide. Any suggestions would be helpful.
-- measure 3 times, cut once
12 replies so far
View joey502's profile
joey502
535 posts in 1511 days
#1 posted 12-12-2015 10:05 PM
I would doubt there will be any way to permanently flatten the board without milling it flat. Even after milling it may bow again.
What is your intended use for the board? How bad is the bow?
View AlaskaGuy's profile
AlaskaGuy
4119 posts in 2303 days
#2 posted 12-12-2015 11:00 PM
Cupped or bowed?
View dbw's profile
dbw
#3 posted 12-12-2015 11:08 PM
Thank you for the clarification. Bowed. I want to cut it into shorter pieces and I need to edge glue two pieces approximately 17” long to make a piece approximately 12” wide.
View bondogaposis's profile
bondogaposis
4717 posts in 2345 days
#4 posted 12-12-2015 11:13 PM
How bad is it bowed? If it is severe, there is not much you can do. I generally will cut boards like this into shorter lengths then mill out the bow and use them for short pieces in the project that call for shorter lengths. Then obtain some more suitable stock for the longer pieces.
-- Bondo Gaposis
AlaskaGuy
#5 posted 12-13-2015 12:03 AM
If you cut that board into 3 17’’ pieces the bow will be significantly less. Set your bowed 8×60’’ piece on edge and place a 17’’ straight edge of some sort against the bowed piece and leap frog the 17’’ straight edge down the piece looking and the gap at each location. The gap you see will be the amount of bow in each of the 17’’ piece. Let us know how much that is.
You say 4/4, is that in the rough or has it been planed to 3/4”
View tomsteve's profile
tomsteve
783 posts in 1213 days
#6 posted 12-13-2015 12:40 AM
Running one face across a jointer then planing to thickness is the usual way to fatten a cupped, bowed, twisted board.
You need 2-17” long pieces. Personally I’d cut 2 pieces 20” long then do the above.
View lateralus819's profile
lateralus819
2241 posts in 1883 days
#7 posted 12-13-2015 12:50 AM
Grab a board stretcher from a box store. Should sort it out.
View Kazooman's profile
Kazooman
1005 posts in 1946 days
#8 posted 12-13-2015 12:58 AM
Wood is wood and it moves. If you really mean all of the capital letters in your PERMANENTLY then you need to switch to machining metal or plastic and even then you might have trouble. With wood you get the dimensions that you make when you cut your pieces and you need to allow for any movement that will occur with changes over time. That is part and parcel of the craft. If everything was made out of plywood then anybody could cobble together one of the classic pieces of furniture. Understanding the movement of the wood and how it will affect the design of the piece is the key to success and it takes a lot of hard knocks. Ask anyone here about their “kindling bin”.
AlaskaGuy:: very nice picture showing the definition of the terms. I think “cupped” is one of the most misunderstood terms here.
AlaskaGuy
#9 posted 12-13-2015 01:08 AM
He’s asking if it can be done without milling it. I have to assume that mean no ruining it across a jointer. Not sure how a board stretcher would work for this. I think his wood is long enough already.
I’ve jointed and planed plenty of wood that has stay flat for years and years.
View dbw's profile
dbw
#10 posted 12-13-2015 05:40 AM
It’s 4/4 (7/8) where one side one edge have already been jointed. I don’t have a jointer and even if I did It would have to be an 8” (quality) jointer, which is out of my budget. By permanently I mean I don’t want the bow to creep back in after the project is finished. I understand wood moves and I have allowed for movement. I do have a planer except I don’t think I can use it to take the bow out because the rollers will temporarily flatten the board and I’ll wind up with a thinner board which will still be bowed.
View Babieca's profile
Babieca
178 posts in 1498 days
#11 posted 12-13-2015 06:09 AM
You can flatten on the planer using a sled with wedges under the board so the rollers will not flatten it. See this video.
https://www.youtube.com/watch?v=8UONmuQt_98
As said above, you’ll want to do this after cutting your pieces to rough length to get a lot of the bow out that way.
It s 4/4 (7/8) where one side one edge have already been jointed. I don t have a jointer and even if I did It would have to be an 8” (quality) jointer, which is out of my budget. By permanently I mean I don t want the bow to creep back in after the project is finished. I understand wood moves and I have allowed for movement. I do have a planer except I don t think I can use it to take the bow out because the rollers will temporarily flatten the board and I ll wind up with a thinner board which will still be bowed.
- dbw
View TheFridge's profile
TheFridge
9444 posts in 1480 days
#12 posted 12-13-2015 06:10 AM
bracing of a sort or mill it.
