Compare crosscut between 40T and 50T blades
Forum topic by abehil posted 12-12-2015 08:01 PM 740 views 0 times favorited 7 replies Add to Favorites Watch
View abehil's profile
abehil
104 posts in 1338 days
12-12-2015 08:01 PM
Topic tags/keywords: table saw question blade review
Is there any way to quantify the crosscut gotten from a 40T (D1040X) versus a 50T combo blade (D1050X)?
I would expect better ripping from the 40T to reduce burning on 1-5/8” stock for instance. But I can’t get a sense on how much better the crosscutting should be when using a 50T when reading about it.
7 replies so far
View conifur's profile
conifur
955 posts in 1151 days
#1 posted 12-12-2015 08:06 PM
It is not just about tooth count, a ribbing blade teeth or more like a chisel, cross cut are alternating angles to chew through the wood.
conifur
#2 posted 12-12-2015 08:16 PM
check out the videos here
http://www.freudtools.com/
View knotscott's profile
knotscott
8015 posts in 3375 days
#3 posted 12-12-2015 10:25 PM
There are a lot of variables in play, and it’s hard to quantify. Tooth count is the most commonly recognized parameter, but there is also significant effect from the hook angle, top grind, side angles, side clearance, etc. There are also a bunch of additional variables in the material, the saw, technique, etc.
Those two blades are obviously of the same quality, and are intended for very similar applications. Considering that any general purpose/combination blade offers a design compromise from optimum performance in favor of versatility, I really wouldn’t worry too much about it….both are really good value blades, and either should be fine as an everyday all-purpose blade. Neither is going to excel at efficient ripping in thick stock, and neither is going to leave nearly perfect tear out free plywood or fine crosscuts. For ripping 1-5/8” stock you’d be better off with a 24T D1024X.
What saw do you have?
Tips for Picking Saw Blades
abehil
#4 posted 12-12-2015 10:51 PM
I should have mentioned that I am already getting a 24T for ripping.
I am trying to choose between a 40T and 50T combo and this choice will be on the saw most of the time. Because of that, I expect I will end up ripping with it when needing just a couple pieces. I want the luxury of being a little lazy. :)
I only cut plywood when I’m building a shop jig so tear out on that isn’t critical to me. Most of the time I’m working with soft woods, mainly cedar for now.
Currently I have an old Grizzly contractor saw. However, I’m buying a Delta 36-725 and that will be my TS for several years I hope. BTW, Lowes has it on 10% sale. Add in my coupon and I’m getting it at what I consider a good price, like around $460
View jbay's profile
jbay
2289 posts in 899 days
#5 posted 12-12-2015 10:55 PM
I’ve been using the Tenryu Gold Medal, 40 tooth, and it has proven to be a great all purpose blade.
View patcollins's profile
patcollins
1685 posts in 2864 days
#6 posted 12-12-2015 11:13 PM
I have a hard time telling the difference in the cuts between a 40T general purpose and a 50T combo blade. Personally I think the 40T general purpose blade is a better choice and when I want really good crosscuts I use a 60T blade.
knotscott
#7 posted 12-12-2015 11:15 PM
- abehil
If I were in your shoes, since you’ve got the 24T covered, I think I’d grab the 60T D1060X and use that for all but the really thick ripping. The 1060 has a steeper hook angle on it than most 60T blades, so it’s actually pretty reasonable in ripping to an inch or so…maybe more depending on the material, but most cedar cuts pretty easily. It’ll leave a cleaner edge than the 40T or 50T, and is definitely the better crosscut blade. For those moments when you want to be lazy and rip thicker stock with it, try raising the blade a little higher…if you keep in clean and sharp, it might surprise you.
