Dewalt 735 planner problems
Forum topic by DavidTTU posted 12-12-2015 06:46 PM 1071 views 0 times favorited 7 replies Add to Favorites Watch
View DavidTTU's profile
DavidTTU
141 posts in 1633 days
12-12-2015 06:46 PM
I have an almost brand new Dewalt 735. I had it put away for several months and got it out today to work on some projects. When I try planning a board it is as if the front roller has sagged. The depth gauge is no longer registering and my work piece is slamming into the front roller without coming into contact with the blades. This is causing lots of friction and the work piece will not push through. I checked to see if the blades were set up well and I believe they are. There really isnt much adjustment with the blades. Is it possible that my roller has sagged? Or is there a way to raise it? Any help would be appreciated.
Problem summarized. the work piece is hitting the rollers and not the blades. The only way to get the blades to come in contact with the work piece is by putting a far to deep of cut based off where it is hitting the rollers. Everything mechanically is operating perfectly.
Do you think this is a roller problem, blade adjustment problem, or a table problem?
I tried it with several flat workpieces, it is not because they are twisted.
-- -David -- Lubbock, TX
7 replies so far
View gwilki's profile
gwilki
200 posts in 1471 days
#1 posted 12-12-2015 10:22 PM
Is the chain running on all four sprockets?
I’m assuming that it was working fine when you put it away, so this is a bit weird.
-- Grant Wilkinson, Ottawa ON
View pintodeluxe's profile
pintodeluxe
5658 posts in 2810 days
#2 posted 12-12-2015 10:59 PM
As far as the planer not pulling stock through, the most common causes are dull blades and friction against the tables. For that part of the problem, wax the planer beds and replace the blades. I was getting 200 b.f. or less per blade change, which is why I switched to a Shelix head.
The gauge not working could be a separate problem. I had a splinter of wood jam in my material removal gauge once, and it quit working. Clearing the debris and cleaning it with compressed air solved the problem.
Try raising the cutterhead for a lighter cut. Repeat this until the board feeds through.
If all this fails, I fear you may have a more serious problem. However 90% of problems with this planer can be fixed with cleaning, waxing the beds, and flipping or replacing the blades. I have found that dull planer blades look and feel the same as sharp ones, but they won’t let the lumber feed through. The infeed roller will grab the lumber, but can’t move the lumber because the blades are dull.
View Ub1chris's profile
Ub1chris
116 posts in 1377 days
#3 posted 12-13-2015 02:29 AM
- pintodeluxe
200 BF per blade change? Your blades must have been made of cheese.
pintodeluxe
#4 posted 12-13-2015 06:35 AM
Ub1chris,
The stock Dewalt 735 blades are absolute garbage. They cut clean, but nick easily and dull very quickly.
Upgrading to the Shelix was the best change for me. It’s been a year now, and I haven’t even rotated the cutter inserts yet. I was dropping $55 every time I walked through the tool aisle at Lowes. Now I just smile and walk on by.
I usually mill figured white oak and big leaf maple, so people who work with softer woods may get more mileage from their blades.
View OSU55's profile
OSU55
1667 posts in 1987 days
#5 posted 12-13-2015 01:46 PM
I probably ran 800 board feet of mostly oak through mine before flipping the blades. Depth of cut has everything to do with blade life in the 735. I try not to take more than a 1/32, 1/2 turn, for each pass. Granted it can take a while if one is wanting to remove substantial thickness.
pintodeluxe
#6 posted 12-15-2015 05:08 PM
The results I mentioned were with 1/32” depth of cut.
OSU55
#7 posted 12-15-2015 09:53 PM
Cant explain a 4 to 1 difference in blade life. My experience is with kiln dried common red oak with knots and all, but it is clean – no dirt or rocks.
