| Forum topic by llanaro | posted 1228 days ago | 909 views | 0 times favorited | 6 replies | ![]() |
1228 days ago |
Hi All I have read several options here on heating garage.. Anyone know if taking a heat run from the house into the garage is legal here in Ontario. I can pop in about a 3’x6” run from the basement to garage no problem. Everytime the furnace fires up it would push some heat and keep the garage at least above freezing. It is -8C now and the garage is at or above 0 if I don’t open the doors.. also well insulated and would keep the room above the garage also warm regards |
#1 posted 1228 days ago |
Sorry I don’t know in Canada, though typically Canada is MORE strict on a lot of codes. Obviously one can ensure that won’t happen but no code inspector would give it a thumbs up, and it would have to be taken out if you wanted to sell the house. I would go the space heater route, unless you really want to keep the garage heated all the time. When I bought it 3 years ago I paid $219 but there is no exposed heating element, so I never had to worry about fire from sawdust. -- "_If we did all the things we are capable of doing, we would literally astonish ourselves_." Edison |
#2 posted 1228 days ago |
One word; kerosene. |
#3 posted 1228 days ago |
I bought one for my two car garage similar to Dave’s. It’s 5000 watt 240volt 30 amp. It’s made by Cadet it’s called the HOT ONE. Ive had it about a week and it works great, although we don’t have the temps like you did. I was able to get the garage to heat up from 30 deg f to 60 deg f in about 25 minutes. My garage is 400 sq ft. with an 8’ 6” ceiling. I paid $225.00 U.S. they make two versions under the same name one is 4000 watt and the bigger is 5000 watt. Get the bigger one if you’ve got the circuit for it. http://www.cadetco.com/show_product.php?prodid=1012 -- www.thepatriotwoodworker.com Proud Supporter of Homes For Our Troops |
#4 posted 1202 days ago |
Even at -8 you don’t really need to heat the garage for the car as -8 or +8 doesn’t really make that much difference to the longevity of the car. If you are storing paint or whatever that is a different question. I use a 4800 watt electric ( on a 240 volt circuit) when I want to work in my shop which is the none car part of my 2 car garage. It was coolish here the other day (mid -20s C) and I had the shop up to 18 degrees in a couple of hours, I actually had to turn the heat down as I was planing some drawer sides and was getting too warm. As mentioned, in earlier posts, I don’t think it would be wise to give CO a chance to leak down into the living quarters, and these electric heaters are inexpensive to run. -- "Checking for square? what madness is this! The cabinet is square because I will it to be so!" Jeremy Greiner LJ Topic#20953 2011 Feb 2 |
#5 posted 1202 days ago |
I use natural gas -- W James Brokenbourgh Custom furniture maker http://artisticwoodstudio.com/ |
#6 posted 426 days ago |
Is it possible to just install designer radiators in the garage? I wonder if that will be an affordable option for you. I do not know of any other ways to help you though. |
| Forum | Topics |
Woodworking Skill Share
8790 |
Woodturning
220 |
Woodcarving
28 |
Scrollsawing
61 |
Joinery
78 |
Finishing
1529 |
3547 |
15767 |
Hand Tools
2034 |
Jigs & Fixtures
495 |
Wood & Lumber
2837 |
808 |
Focus on the Workspace
901 |
766 |
Woodworking Trade & Swap
2740 |
LumberJocks.com Site Feedback
1547 |
Coffee Lounge
6155 |
