What is the difference between board foot, and linear foot?
« back to Coffee Lounge forum
Forum topic by Hooligan__j posted 1231 days ago 8396 views 1 time favorited 14 replies Add to Favorites Watch
View Hooligan__j's profile
Hooligan__j
18 posts in 1238 days
1231 days ago
I am a noob, as far as purchasing wood, other than plywood, and framing type lumber.
I am asking because at Ye Olde Home Despot, some woods are priced by linear foot, and at other places they are priced by board foot. Are these the same?
Thanks in advance for your help.
14 replies so far
View knotscott's profile
knotscott
4202 posts in 1546 days
#1 posted 1231 days ago
A linear foot is 12” of length regardless of width. A board foot is any dimensional equivalent of 1” x 12” x 12”, such as 1” x 6” x 24”, or 2” x 6” x 12”.
View northwoodsman's profile
northwoodsman
227 posts in 1917 days
#2 posted 1231 days ago
I want to add that even if it is less than 1” thick, it is most often still regarded as 1” thick.
-- NorthWoodsMan
View Andrew's profile
Andrew
709 posts in 1369 days
#3 posted 1231 days ago
in other words, to calculate a boardfoot,( BF) Multiply thickness by width by legnth, then divide by 144.
easy a 1” X 6”X 24” =144 divided by 144 = 1 boardfoot
or 2” X 4” X 44” = 352, this is cubic inches, divide by a square foot ( 144”) and you get 2.44 Boardfeet.
Hope that helps.
Realtor jim is correct, it should be square feet, and sqare inches, I think, now I’m so confused, the mutiliplication measures cubic feet, then is divided by a square foot. Anyway the calculations above are correct except for some of the terminology.
-- Even a broken clock is right twice a day, unless, it moves at half speed like ....-As the Saw Turns
14858 posts in 2389 days
#4 posted 1231 days ago
One easy way to think of it is that a board foot is basically the same as a cubic foot. (Not exactly, of course, because a 1×12, for example, is not really 1” thick. But in terms of doing the math it is the same.)
View RealtorJim's profile
RealtorJim
29 posts in 1283 days
#5 posted 1231 days ago
Ummm… Charlie…. unless I am mistaken a cubic foot is actually 12 board feet. 12”X12”X12”.
I think you are using the measurement method that I usually use when I CUT my lumber, then realize I errored AFTER the cut has been made.
-- "If you can't find it, build it. If you can't build it, then you must need some more tools."
View Dennisgrosen's profile
Dennisgrosen
10854 posts in 1285 days
#6 posted 1231 days ago
EXcuse for asking if it isn´t the right place for it then plaese send me a pm insted
I see so many bieutyful plans on the net and nearly all of them and the cutting list is
only made with inch and boardfeet mesagers and not with cm and meter and sq.meter
my question is how do I calculate from one to the other ?
Dennis
RealtorJim
#7 posted 1231 days ago
1” = 2.54 cm
1’ = 30.48 cm
39.37” = 1 meter
1 square meter = 10.7639 sq. ft
cm x 0.39 = in
in x 2.54 = cm
I “think” this is correct. But you can download free metric conversion programs off the internet or use an online conversion site. Just do a search for “metric conversion calculator”. One such site (that I just searched, so I do not really know anything about it, other than it does offer online conversions) is;
http://www.metric-conversions.org
Hope this helps.
#8 posted 1231 days ago
Ouch! Mea culpa.
My head was thinking “144 cubic inches” while my fingers were typing “cubic foot”.
RealtorJim
#9 posted 1231 days ago
It happens Charlie. That’s why we have “designer firewood”.
Dennisgrosen
#10 posted 1231 days ago
´Realtor Jim
thank´s the first two I know
but the next two I wasn´t qiet sure of
and thank´s for the link
View Jerry's profile (online now)
Jerry
1431 posts in 1717 days
#11 posted 1230 days ago
I am a bit of a newbie myself at a lot of this. I once did a 8/4 butcher block for a customer and ended up doing it for free because of my miscalculation on what an actual bf was. Now I know though, not to make that mistake again.
-- Jerry Nettrour, San Antonio, www.topqualitycabinets.net
View Chuck 's profile
Chuck
89 posts in 1370 days
#12 posted 1230 days ago
I have plans that call for a board of 1.5 furlongs by 2 cubits. How many board feet would that be/?
-- Chuck, Washington D.C.
View Jim Jakosh's profile
Jim Jakosh
7310 posts in 1276 days
#13 posted 1230 days ago
Hi Hooligan. A board foot is a 1 foot long by 1 foot wide by 1” thick. Narrow boards are factored by the fraction of the foot that they are. So if you have a 3/4” board that is 8” wide, it is 2/3 of a foot wide by the length and 3/4” is considered 1” thick for usual calculations. If the wood is thinner than 3/4” and expensive, I ask for the thickness to be factored as part of and inch thick in the formula.
-- Jim Jakosh.....Practical Wood Products...........Learn something new every day!!
View rtb's profile
rtb
1097 posts in 1883 days
#14 posted 1230 days ago
Kind of had to get anything out of all these formulas ?? I always think of a board ft as a measurement of the volume of wood vs; a lineal foot as being just a measurement of length . So. a board foot could be 1×12 x 12 or 1×6 by 24 the volume of wood remains the same. while a measurement of 25ft is simply a distance.
-- RTB. stray animals are just looking for love
