Video
Forum topic by jim1mckenna posted 01-08-2010 07:50 PM 907 views 0 times favorited 3 replies Add to Favorites Watch
View jim1mckenna's profile
jim1mckenna
51 posts in 3054 days
01-08-2010 07:50 PM
Topic tags/keywords: resource question video
I wanted to start to put some videos on internet was woundering what type of programes people use and what is the process, I have a PC not a mac. Any type of advice
3 replies so far
View Icemizer's profile
Icemizer
88 posts in 3503 days
#1 posted 01-11-2010 06:44 PM
Video on the web can be as simple or complex as you want it to be. If its a newer pc it probably has windows movie maker built in. This is an easy program to use and will give you a general idea on how to use timelines to build a project. It also has lots of settings for output.
Moving up there are programs from Sony and Pinnacle which will allow you to do more but again the learning curve gets higher the more you want to do.(hey just like this hobby!)
If you are going to be playing with HD video you will need a newer machine with lots of power to grind away at rendering the large size of HD files.
-- Say what you mean and mean what you say.
jim1mckenna
#2 posted 01-11-2010 09:27 PM
I do have a hd camcorder, and a super fast and powerful PC. What do you mean grind away at rendering?
Icemizer
#3 posted 01-12-2010 03:18 PM
Putting video into a computer is easy and generally happens in real time.(Unless your camera has a hard drive then you can just transfer files.)
Getting video out is another story. The computer has to render every frame of video and convert it down to the file type you want. Full size SD video is 720×480. Most video put on a website is half that, 320×240 or smaller. Hd video is even larger and contains more information so the render down process will take longer.
If you add graphics and effects the computer will have to render the effects into the mix and add more time to the process(more complex effects like green screen take even longer)
Now we are not talking days here or even hours. Just want you to know this will not happen instantly.
Even if you have a multi core computer it will take time as I dont believe any current consumer editing program has the ability to use multiple cores.
