Some advice needed on finishing waterbased dye
Forum topic by Rob posted 12-12-2015 04:56 AM 707 views 0 times favorited 10 replies Add to Favorites Watch
View Rob 's profile
Rob
216 posts in 3909 days
12-12-2015 04:56 AM
I’m making a crokinole board that has a plain birch playing surface and outer rail that match. I’ve already covered the playing surface which is still separate with a waterbased polyacrylic. Now for the base; I’ve dyed the base dark with an aniline dye which is also waterbased. Then I’ve glued the natural birtch rail around that and I plan to clear coat both of them together however I’m worried that the dye will run into the natural birch when hit with the waterbased clear.
One way to solve this would be to use an oil based poly instead however I worry that it will yellow on the rails and look different than the clear playing surface (deck).
I also know another option is to use a shellac as a sealer over the dye.
So I’m just wondering which would be the best route to go here and perhaps there is something that I haven’t considered then please let me know. Thanks.
10 replies so far
View Ger21's profile
Ger21
1075 posts in 3372 days
#1 posted 12-12-2015 11:45 AM
Use two light coats of de-waxed shellac to seal it.
-- Gerry, http://www.thecncwoodworker.com/index.html http://www.jointcam.com
View Tennessee's profile
Tennessee
2893 posts in 2756 days
#2 posted 12-12-2015 12:16 PM
I’ve got to ask…what the heck is crokinole?
5244 posts in 2735 days
#3 posted 12-12-2015 12:37 PM
Gerry nailed it…
View AandCstyle's profile
AandCstyle
3185 posts in 2498 days
#4 posted 12-12-2015 01:44 PM
Rob, if you don’t to darken the lighter wood, use blonde or super blonde shellac.
-- Art
View conifur's profile
conifur
955 posts in 1393 days
#5 posted 12-12-2015 02:49 PM
Some dyes, Trans Tint liquid dye is both water and alcohol based for sure, since I use them alot. So if using them, you have to do an oil based wash coat over it to seal it.
#6 posted 12-12-2015 03:09 PM
- conifur
Good point. Shellac can still be used, but it would have to be sprayed, in very light coats.
conifur
#7 posted 12-12-2015 03:24 PM
Fred thanks, I dont spray so forgot to mention that.
117423 posts in 3818 days
#8 posted 12-12-2015 03:36 PM
Like you and other have stated Rob,your dealing with like on like, dye and top coat solvents,in this case water.The top coat if brushed on will cause a percentage of the dye to come off or more around. If you’re spraying it your shouldn’t have a problem at as long as you apply polyacrylic the way you’re suppose to. If you’re brushing it on then you do need to seal it off with some dewaxed shellac.
View Rob 's profile
Rob
#9 posted 12-12-2015 03:41 PM
Like you and other have stated Rob,your dealing with like on like, dye and top coat solvents,in this case water.The top coat if brushed on will cause a percentage of the dye to come off or more around. If you re spraying it your shouldn t have a problem at as long as you apply polyacrylic the way you re suppose to. If you re brushing it on then you do need to seal it off with some dewaxed shellac.
- a1Jim
Thanks Jim, I can spray it so I’ll just do that then. That great because I wanted to do the light coloured sides at the same time. Much appreciated.
#10 posted 12-12-2015 03:51 PM
Glad to help Rob just don’t puddle the polyacrylic by spraying a super heavy first coat. I use water base dye and polyacrylic all the time.
