Making Lathe tools
« back to Coffee Lounge forum
Forum topic by poopiekat posted 01-08-2010 05:55 PM 1385 views 0 times favorited 4 replies Add to Favorites Watch
View poopiekat's profile
poopiekat
4408 posts in 3976 days
01-08-2010 05:55 PM
Topic tags/keywords: question
I just ordered some carbide inserts for metal-working lathes, with the intention of fabricating a toolholder made of steel bar. Most of these inserts are specifically made to cut threads on round metal stock, but I saw one that is round and perhaps had some possibilities for woodturning. see this link: http://www.mcmaster.com/#7376a319/=5abcwc
These inserts are usually solid carbide or Titanium coated and keep an edge for a long time. Has anyone ever tried using these metalworking cutters on wood?
View lew's profile
lew
12514 posts in 3997 days
#1 posted 01-08-2010 06:51 PM
I made a lathe duplicator using 1/4” x 1/4” piece of HSS tool bit stock. It seemed to work well once I got the angle correct on the cutter.
poopiekat
#2 posted 01-08-2010 07:27 PM
Thanks, Lew! Yeah, I’m a bit unsure of ‘rake angle’ but I’m mostly puzzled as to why everyone isn’t using metalworking carbide inserts. It just looks like it’s the right tooling to use for woodturning!
View marcb's profile
marcb
768 posts in 3915 days
#3 posted 01-08-2010 07:50 PM
The geometry for cutting metal is extremely different for that of traditional wood cutting tools.
Report back with results as I’m wondering how well these will work.
View lew's profile
lew
#4 posted 01-08-2010 08:15 PM
The cutter “angle” that worked best for my application (french rolling pin arc) was grinding a rounded end. If plunged straight in, it would make a cove cut. However, it also gave me the cleanest cut when moving it along the horizontal axis of the rolling pin. I tried a cutter ground for removing metal along the horizontal axis and it gave a rough/ragged cut.
