Greene and Greene ebony plugs
Forum topic by grace123 posted 12-12-2015 12:00 AM 709 views 0 times favorited 6 replies Add to Favorites Watch
View grace123's profile
grace123
228 posts in 2672 days
12-12-2015 12:00 AM
I want to make a chest for my grandson for an upcoming birthday. He will be 8 years old. I want to make a scaled-down version of a Greene and Greene blanket chest with the idea that as a younger boy he can keep toys in it, but as he grows he will keep things are significant to him in it. I envision it will get a lot of use. Do the ebony plugs come out? I would hate to have some of the plugs work loose.
View jmartel's profile
jmartel
7687 posts in 2059 days
#1 posted 12-12-2015 12:33 AM
The plugs are typically glued in, so no they won’t come out. Also, since ebony is super expensive, African blackwood makes a pretty good alternative, though sometimes it can be lighter and show grain.
View RogerM's profile
RogerM
790 posts in 2308 days
#2 posted 12-12-2015 01:19 AM
Another alternative is walnut stained with a Sharpie Permanent marker.
-- Roger M, Aiken, SC
View bondogaposis's profile
bondogaposis
4611 posts in 2261 days
#3 posted 12-12-2015 02:04 AM
Wenge is another potential substitute and it is cheaper and easier to get. Not quite as dark but dark enough to contrast w/ most other woods. The plugs shouldn’t come out if they well glued and fit tight.
-- Bondo Gaposis
View shampeon's profile
shampeon
1775 posts in 2093 days
#4 posted 12-12-2015 02:04 AM
Yeah, look up “ebonized wood”. It’ll be a lot cheaper than using actual ebony.
jmartel
#5 posted 12-12-2015 02:50 AM
I’ve used walnut with steel wool and vinegar solution in the past that worked well. The problem with that is if you sand/plane/scrape something flush, then you get rid of the dark stain. Coloring it in afterwards is a recipe for disaster as well. Tried that and it failed. Hence my suggestion for African Blackwood.
For plugs and splines in the G&G style though, it should work well. You don’t sand stuff flush, so there’s nothing to worry about.
View lateralus819's profile
lateralus819
2241 posts in 1799 days
#6 posted 12-12-2015 02:51 AM
I spent $40 on a 2×2x12” blank of ebony.
I used maybe $10 worth for my chest. For every piece. It goes a long way.
When you do them use a cordless drill. I tried a drill press and it leaves a swirl. Something about the unevenness of a hand held drill works the best.
