Nova G3 Chuck
« back to Woodturning forum
Forum topic by DonJ posted 12-09-2015 03:49 PM 788 views 0 times favorited 4 replies Add to Favorites Watch
View DonJ's profile
DonJ
250 posts in 3496 days
12-09-2015 03:49 PM
I’m new to turning and purchased a used Jet Mini. I picked up a new Nova G3 the other day, as it said it was “ideal” for mini lathes. I unpacked it today and found the threaded female mount is way too large for the male thread on the lathe. Do I have to get something extra to make it fit? Thanks.
-- Don, San Antonio, TX
woodbutcherbynight
4354 posts in 2378 days
#1 posted 12-09-2015 03:52 PM
a 8×1 adapter, you can find them on amazon.
View DonJ's profile
DonJ
#2 posted 12-09-2015 04:00 PM
View johnstoneb's profile
johnstoneb
2871 posts in 2141 days
#3 posted 12-09-2015 04:42 PM
Yes
-- Bruce, Boise, ID
View LeeMills's profile
LeeMills
522 posts in 1270 days
#4 posted 12-09-2015 06:25 PM
The 1 X 8 should be what you need. Check your spindle specifications to be sure.
Also the “D” insert does not have the setscrew for reverse, IF your lathe has reverse.
If it has reverse (usually for sanding) I suggest the “X” insert instead. A couple of $$ more but already has the set screw.
Most lathes have a shoulder on the spindle at the headstock. A few are threaded all the way. Per the manufacturer do not use the “X” if yours does not have an unthreaded shoulder/register.
