Mitered Frame around solid core?
« back to Joinery forum
Forum topic by onesojourner posted 12-09-2015 01:05 PM 742 views 0 times favorited 6 replies Add to Favorites Watch
View onesojourner's profile
onesojourner
73 posts in 1682 days
12-09-2015 01:05 PM
I am building a small game board, around 8×8 inches by 3 inches. The Top is going to be a piece of crotch walnut and that is currently about 1/4 of an inch thick. If I need to take that down I can do that on a drum sander. I need to put some kind of frame around this but I am worried about wood movement. I had planned on doing about 3 layers of walnut for the core, but I am worried about wood movement. I would prefer to stay away from MDF/ply if possible. I also plan to have a small drawer, something like 2×2x1 for the pieces in the board. Any tips would be greatly appreciated.
-- http://icftfsystemshome.blogspot.com/
View Nicky's profile
Nicky
695 posts in 4058 days
#1 posted 12-12-2015 06:22 PM
Alternate the grain of the core, and use 5 plys instead of three. Plywood gets its stability from alternating grain layers. Be sure that each layer is completely covered with a thin layer of glue. Maybe you can think that if you make the core yourself, you don’t need to call it plywood.
-- Nicky
View jerryminer's profile
jerryminer
916 posts in 1407 days
#2 posted 12-12-2015 08:05 PM
- onesojourner
You are wise to be concerned about wood movement. What is your objection to plywood or MDF? For stability, they are hard to beat.
If you insist on a solid wood core, use the most stable, quartersawn stock you can find. But MDF/ply would work better here, IMHO
View jumbojack's profile
jumbojack
1674 posts in 2590 days
#3 posted 12-13-2015 05:07 AM
8 inches, three layers, alternating grain, IMHO there will be no problem. Miter away.
onesojourner
#4 posted 12-13-2015 02:36 PM
Thanks guys. My main reason is solid wood is cheaper and I already have it.
It turns out what had was quarter sawn. So I ripped the board in half and got them milled up. I glued the panels glued up and ran them through the drum sander to make sure they were good and flat. I glues the 3/16th vaneer to one part of the core and and I glued the other two part of the core together. I will do the final glue up today.
onesojourner
#5 posted 12-13-2015 07:16 PM
onesojourner
#6 posted 12-14-2015 04:43 AM
