Stanley Bailey #6 - what type?
« back to Hand Tools forum
Forum topic by RSetubal posted 12-08-2015 12:48 AM 1017 views 2 times favorited 10 replies Add to Favorites Watch
View RSetubal's profile
RSetubal
31 posts in 1326 days
12-08-2015 12:48 AM
Hello,
I found this plane in Brazil. It’s a Stanley Bailey # 6, modified and damaged.
The frog was restored. It was broken.
I began to restore, but do not know what kind. I found information on type 11 or type 14.
Can anyone help identify the type of this plane?
I have a few photos.
I do not know where to find the damaged parts.
For your attention, thank you.
10 replies so far
View benchbuilder's profile
benchbuilder
284 posts in 2478 days
#1 posted 12-08-2015 11:55 AM
Hi RS, You could start by looking at a site on the net called, Blood and Gore, this is all about hand planes. it should help you type the plane. Also there is a guiy that sells just plane parts, it the nhplaneparts and hes got everything you need at good prices.
View rwe2156's profile
rwe2156
2967 posts in 1508 days
#2 posted 12-08-2015 12:26 PM
For determining type: hyperkitten.com.
Incomplete or damaged planes the cost of replacement parts may excede the value of the plane.
Lots of people do it for the fun of it. You have to determine that for yourself.
Before proceeding, I would check the sole for flatness to make sure you have a useable plane first.
RSetubal
#3 posted 12-08-2015 12:48 PM
- benchbuilder
Thanks for the info. I identified the seller on Ebay. Now I will try to find out what kind to buy the correct part.
- rwe2156
You’re right. Some parts cost more than a plane. The plane is for my use. Only the frog was damaged, but was repaired carefully.
The sole is flat. The mouth is also perfect. I will try to post a photo.
Again, thank you.
RSetubal
#4 posted 12-08-2015 01:22 PM
Other pictures:
1) frog – adjustment screw: taken from another plane; the plastic came on the plane
2) tote and knob: build
3) Handle bolt & nut / knob bolt & nut: taken from another plane
View rjpat's profile
rjpat
43 posts in 2006 days
#5 posted 12-08-2015 07:50 PM
I don’t think that you would find that lever cap with that frog, the lever cap is from a much earlier plane.
View hhhopks's profile
hhhopks
651 posts in 2405 days
#6 posted 12-08-2015 08:56 PM
Specific plane type would be hard to tell as you can’t zoom in on the photos and your plane has mixture of parts from other planes. Base on the body I cast my vote to be type 15 or 16. I am looking at the “MADE IN USA” casting at the toe area and there are no broad flat ribs at the toe and heel area.
Agree with rjpat.
The lever cap should have “STANLEY” casting on it. The hole should most likely to be kidney and not key hole shape.
I would make sure that the frog’s surface that mates with the blade is flat if the plane is to be a user. Also I would be concern about the surface where the frog bolts/washer sit. That really should be flat. You don’t want the frog to move as you plane. As a user plane, I would replace the frog.
What parts are you looking for? Lots of guys here on LJ can fix you up if you ask as this should be a common plane.
-- I'll be a woodworker when I grow up. HHHOPKS
bandit571
20255 posts in 2711 days
#7 posted 12-08-2015 09:31 PM
Ebay seller is under …..nhplaneparts.com
Frog is the later fourth version….about post WWII era It would have the “kidney” shaped hole instead of the Keyhole” shape. IF you can find an earlier frog, and the 2-3/8” wide iron, you might be in business.
Difference in frogs. One like yours, next to one that came before the one you need. You need a slot milled like the frog you have now, but with the flat face.
lever caps. the one with the STANLEY would match the frog you have now.
Back of the frogs.
parts for a #5-1/2 a #6 and the #7 are basically the same for each “type” as they are the same width. Might help your search effort that way. The two planes are a #6c, type 10, and a #5-1/2,type 17.
Any of this help you out?
RSetubal
#8 posted 12-09-2015 12:15 AM
I don t think that you would find that lever cap with that frog, the lever cap is from a much earlier plane.
- rjpat
I also conclude that the frog and the lever cap are of different planes.
The type 15 and 16, marked “Made in USA” is behind the frog. In my bed is behind the tote.
http://hyperkitten.com/tools/stanley_bench_plane/tl_16.php
http://hyperkitten.com/tools/stanley_bench_plane/tl_15.php
The lever cap is perfect and frog repaired. I’d better replace the frog, if not impair the function? But do not know which one is suitable frog. A frog of the same model works with this lever cap?
Or is it necessary that the lever cap is the same type of frog?
bandit571, I made a contact with this seller. I’m awaiting return. But it seems that does not send to Brazil.
Then need to change the frog by a flat face?
I conclude to replace the frog broken by a smooth face frog to match the lever cap I already have. It’s the best option?
Thank you all.
View Don W's profile
Don W
18754 posts in 2595 days
#9 posted 12-09-2015 08:11 PM
if you are just trying to find another frog, here is a reference.
The lever cap doesn’t matter unless your trying to be period specific.
RSetubal
#10 posted 12-10-2015 01:21 AM
The lever cap doesn t matter unless your trying to be period specific.
Don W, e image is illuminating.
I do not want to leave the plane according to the period, but want to change the frog broken. If i find a frog in the same period of the the bed will be perfect. And that’s what I need to find out.
Thanks for the comment.
