Will it warp?
Forum topic by 1978 posted 01-06-2010 05:10 PM 961 views 0 times favorited 5 replies Add to Favorites Watch
View 1978's profile
1978
167 posts in 3573 days
01-06-2010 05:10 PM
Topic tags/keywords: workbench building
Got a question. I found some 4”x4”x8’ pieces of lumber from where I work. I thought it would made a great frame for workbench. They came from a frame of a box that held 10 ton machine, so I figured it would hold up a workbench.
The question is could I use lets say 3, 1”x8”x8’ pieces of lumber placed side by side for the workbench top. Would it warp or bow. I don’t have a whole lot of money so I’m trying to do this as cheap as possible.
Any advice would be nice.
Thanks,
Magicman
5 replies so far
View GFYS's profile
GFYS
711 posts in 3435 days
#1 posted 01-06-2010 05:29 PM
maybe, maybe not. I think it would be ok if properly attached to adequate framing.
View Dragonsrite's profile
Dragonsrite
136 posts in 3361 days
#2 posted 01-06-2010 06:07 PM
My thoughts are that that’d be O.K. for a light-duty bench with, as Mics_54 said, adequate framing.
You may be happier with watching craigslist (free section) in Indianapolis and find a solid door or something like what was listed in Minneapolis yesterday; “18 – 4×8 sheets of MDF” and laminate a couple pieces.
-- Dragonsrite, Minnesota
16274 posts in 4182 days
#3 posted 01-06-2010 07:42 PM
Absolutely. But I would also add some 2×4 support underneath.
View Steve Peterson's profile
Steve Peterson
371 posts in 3046 days
#4 posted 01-07-2010 07:36 PM
I agree with Charlie to add some 2×4 supports underneath for cross bracing.
Why not just use 2×4s for the top also. Stronger and cheaper than 1×8s. Where I live, pine 1×8s from the borg probably cost about $6-8. 2×4s are under $2 each. Try to find kiln dried so they won’t leak sap. In California they mix Douglas Fir (DF) and Hemlock Fir (HF) depending on the supplier that day. The price is the same, but DF is a lot stronger.
-- Steve
View bsherman's profile
bsherman
76 posts in 3491 days
#5 posted 01-07-2010 08:06 PM
I made mine from this plan and it works great. (Cheap too.)
http://www.popularwoodworking.com/article/175_Workbench/
I don’t think you would be happy with a 1x top. My old workbench had that and things would bounce off the top from vibration.
-- Brian
