Fabric veneer
Forum topic by Clint Searl posted 12-07-2015 08:00 PM 855 views 0 times favorited 8 replies Add to Favorites Watch
View Clint Searl's profile
Clint Searl
1533 posts in 2358 days
12-07-2015 08:00 PM
I want to veneer cotton fabric to a pair of 15×48 doors that I’m refinishing. The doors have been prepared with a ground coat of latex/acrylic wall paint. The final finish will be waterborne lacquer (Target EM 6000). I’d appreciate any thoughts on what to use to adhere the fabric that will be permanent and compatible with the lacquer. TIA
8 replies so far
View mahdee's profile
mahdee
3883 posts in 1764 days
#1 posted 12-08-2015 12:40 AM
Hi Clint,
I think any natural fabric like burlap would work. If it is close net/woven, Probably contact cement. I would do a test before going for it. I suppose the door won’t be exposed to weather.
-- earthartandfoods.com
View MNgary's profile
MNgary
298 posts in 2413 days
#2 posted 12-11-2015 03:02 AM
3M trim adhesive, product id: 08074.
You will need to test a small piece to see if your lacqer will affect it, tho. I would try thin coats of the lacquer so it sets up on/in the fabric instead of saturating the fabric so the lacquer comes in contact with the adhesive.
-- I dream of a world where a duck can cross the road and no one asks why.
View Mark Kornell's profile
Mark Kornell
1169 posts in 2527 days
#3 posted 12-12-2015 06:46 AM
Regular yellow or white glue works very well as adhesive to join natural-fibre fabric (cotton/sisal/burlap etc.) to wood. The key things are that the wood must be raw, not finished, so the glue adheres to the wood. And that the glue impregnates the fabric all the way through, so you’d need to be topcoating with something pigmented.
If.are looking to have the fabric as the finished surface on top of a painted surface, I’d try a water-based paste adhesive. Either the craft-store type or a wallpaper adhesive.
-- Mark Kornell, Kornell Wood Design
View Tennessee's profile
Tennessee
2873 posts in 2511 days
#4 posted 12-12-2015 01:01 PM
I’d use Titebond III spread really thin. I’d sand the latex before to give it a better grip.
Waterproof, has a really long set time so you can work out any problems with the fabric, and should be impervious to any chemicals in the waterborne lacquer. It does dry with a amber tint, though. That might be a show-stopper.
How thin is the cotton fabric? A lot of what is being suggested might migrate through the cotton, changing the color and texture of the fabric.
View rwe2156's profile
rwe2156
2925 posts in 1477 days
#5 posted 12-12-2015 03:02 PM
Contact cement you would have to figure out how to keep fabric stretched evenly tho might be a headache.
I think wood glue might soak into cloth and look bad.
I like the wallpaper glue idea because you can manipulate the fabric to get an even stretch.
117090 posts in 3573 days
#6 posted 12-12-2015 03:19 PM
Clint Searl
#7 posted 12-16-2015 02:17 AM
I ended up using a waterborne floor finish (Bona Mega), first brushed heavily on the acrylic ground coat, with the fabric laid into it, followed by brushing a copious amount on the fabric to saturate it. The challenge was to brush out the fabric to eliminate wrinkles and bubbles before the finish dried too much. There are some small wrinkles now frozen in the cured finish. Now to give it more clear topcoats .
Thanks for the suggestions.
View bondogaposis's profile
bondogaposis
4725 posts in 2348 days
#8 posted 12-16-2015 04:32 AM
Perhaps using a small squeegee like they use in fiberglass layup would have helped. Your technique sounds very similar.
-- Bondo Gaposis
