Bentwood rings
Forum topic by Chris posted 01-06-2010 06:38 AM 3438 views 0 times favorited 5 replies Add to Favorites Watch
View Chris's profile
Chris
4 posts in 3063 days
01-06-2010 06:38 AM
Topic tags/keywords: question arts and crafts
i see the word very often but have no idea how to approach this method of making rings.
do you use a few pieces of veneer?
or do you steam bend one piece of wood?
what size should the wood be to start steaming?
please help :)
5 replies so far
View scrappy's profile
scrappy
3507 posts in 3431 days
#1 posted 01-06-2010 07:25 AM
Check out Frank Lads blog on makeing wooden rings.
http://lumberjocks.com/FrankLad/blog/8627
Hope this helps.
Scrappy
-- Scrap Wood's the best...the projects are smaller, and so is the mess!
View lotus's profile
lotus
33 posts in 3411 days
#2 posted 01-06-2010 05:19 PM
I don’t see any bending in this blog. I too have been interested in just how to bend little slivers of wood to such a tight radii.
Chris
#3 posted 01-06-2010 06:22 PM
lotus,
that’s what i’ve been wondering about as well
hopefully someone can shed some light on the issue
scrappy
#4 posted 01-07-2010 07:09 AM
Mabey I got the wrong blog. Check out Frank Lad’s work. He seems to be the ring master around here.
View amcharn's profile
amcharn
5 posts in 3077 days
#5 posted 01-08-2010 11:40 PM
Not sure what you are talking about…....so of course I’ll give an answer! I have made small rings on a lathe. Make a blank cylinder, then start making grooves at consistent distances. You now have “hills” in your cylinder. Come at these “hills” from the side, cutting them free midway up the hill. They will literally “pop” off the cylinder when the web holding them on become very thin. You can then stop the lathe and remove them one at a time. I’m probably way off from what you want, but these are fun to make anyway!
-- Al, Indiana http://uniqueboxart.com
