Marking triandle
Forum topic by niki posted 11-01-2007 11:09 PM 1102 views 2 times favorited 2 replies Add to Favorites Watch
View niki's profile
niki
426 posts in 3984 days
11-01-2007 11:09 PM
Good day
I found those plastic drawing triangles very, very accurate so, instead of buying one of those metal marking triangles..that are changing “moods” according to the season (and from checking them in the shops – not so accurate), I made them from more stable materials like plywood or plastic.
For the base, you can use any man-made board like, plywood, MDF or even “floor panels” because they have very consistent in thickness.
Usually, I use 8 mm (5/16”) floor panels for the big triangles but, for that one on the pics that is 2mm thick, I used 4 mm (5/32”) plywood
After the modification, you can still use the triangle to check for squareness.
And the rest is very simple…
Regards
niki
2 replies so far
View TomFran's profile
TomFran
2957 posts in 3898 days
#1 posted 11-02-2007 02:53 AM
Great idea, Niki! Thanks for sharing.
View TomK 's profile
TomK
504 posts in 3779 days
#2 posted 11-02-2007 05:22 AM
I’ve been coveting a set of aluminum squares, but yours make more sense, as you can also vary the angles like draftsmans (is there such a thing anymore in the age of CAD software) triangles, 45-45-90, 30-60-90 etc. I’m going to take a shot at making these accurately.
Thanks
-- If you think healthcare is expensive now, wait until it's free! PJ O'Rourke
