Wiring - Ward Power Kraft Model TPC 2610C
Forum topic by TexAcoon posted 12-07-2015 02:43 AM 758 views 0 times favorited 9 replies Add to Favorites Watch
View TexAcoon's profile
TexAcoon
8 posts in 1142 days
12-07-2015 02:43 AM
I have a question about the wiring …. I recently purchased Kraft Model TPC 2610C and the switch was removed from the handle by the previous owner. When I got it home … and removed the handle … There were four wires in the handle open … White – Black – Red – Red …
My question is how this was originally wired? ... is there a brake on the motor for this particular saw that has to be energized do to the other set of wires …
Either way I just need help identifying the wires so I can wire this unit back together … Thanks!
New Thread from:
9 replies so far
View DIYaholic's profile
DIYaholic
19750 posts in 2914 days
#1 posted 12-07-2015 04:32 AM
Here is a link to the manual….
http://vintagemachinery.org/pubs/detail.aspx?id=2981
View dhazelton's profile
dhazelton
2805 posts in 2536 days
#2 posted 12-07-2015 01:16 PM
Does the motor show an optional 220 volt wiring diagram?
TexAcoon
#3 posted 12-07-2015 01:34 PM
That’s t the problem it doesn’t have a wiring diagram … However I took the motor completely apart last night… Its 120vac has brushes that look good …. I really believe the motor is burned up … I will have to doe some test on the unit to see. There wasn’t any start cap for the motor …
View MrUnix's profile
MrUnix
7107 posts in 2438 days
#4 posted 12-07-2015 01:37 PM
If it’s a brush type motor, there is no start capacitor.
TexAcoon
#5 posted 12-07-2015 02:00 PM
Thanks Brad .. your correct .. brush motors do not have a start cap …
I was answering dhazelton’s answer from a previous post on a different thread.
Seems these saws had different types of motors installed ..
MrUnix
#6 posted 12-07-2015 02:05 PM
Got ya… what makes you think the motor is burned up?
TexAcoon
#7 posted 12-07-2015 02:10 PM
(motor bad) I don’t … I need to megger the windings and check the commutator and wiring to validate the motor is good… However, as a positive .. There was not any smell of burn or dark spots on either…
Just need to do some test to see what the real problem is .. everything else checked out .. The outboard bearing was pretty ruff .. need to replace that – what was odd it didn’t have a shield on the bearing where the other one did … LOL
TexAcoon
#8 posted 12-07-2015 02:14 PM
As a note, I wrote to Tool Kraft this is what they wrote me for those needing parts or communications with these folks:
Please call on Wed. or Thurs. and Giorgio can walk you through it. Thank you.
Currently, we are open only Wed. and Thurs., 9:00-4:30, EST.
Please call us then. Thank you.
Toolkraft Parts
PO Box 80777
Springfield, MA 01138-0777
Phone: (413) 737-7331
Fax: (413) 737-1526
E-mail: parts@toolkraft.com
To buy: Call us with MasterCard or Visa
for orders over $15.00 or send
a check or money order to TOOLKRAFT
at the address above. (If you send
a check be sure to include the part or
model number of your machine.)
TexAcoon
#9 posted 12-09-2015 09:52 PM
Scratch scratch scratch …. Don’t know what happened… After disassemble the motor and checked everything out didn’t find any issues, I reassembled the motor ..
Did a bench run … and Wala! it ran! ...
So I went ahead and hooked everything back into place and installed my blade .. Gave it a test run cutting wood and seems everything is normal? ...
Funny how that works .. Only think I can think of is one day I’ll have some big job and the thing will all of the sudden stop working, and I’ll be back to the circular hand saw …
Anyway .. thanks for all the support on getting my unit working… Now all I have to do is replace the board top .. it was kind of wore out..
