Wooden camera tripod
Forum topic by PopsHuckster posted 01-05-2010 08:57 PM 12458 views 2 times favorited 15 replies Add to Favorites Watch
View PopsHuckster's profile
PopsHuckster
157 posts in 3068 days
01-05-2010 08:57 PM
Along with my woodworking hobby and old cars, I’m into digital photography (I should just say photography because I’ll never get rid of my film camera). I’ve had all kinds of equipment but really want and old wooden style tripod. I don’t want t buy one…I want to make one. Anybody have plans for such a project?
-- Pop
15 replies so far
View Jim's profile
Jim
98 posts in 3088 days
#1 posted 01-05-2010 11:41 PM
Search eBay for Zone VI Tripod – They made really nice wooden tripods it two sizes. It might give you some ideas.
Jim
-- Artificial Intelligence is no match for Natural Stupidity….
PopsHuckster
#2 posted 01-06-2010 04:24 AM
Did a general search for Zone VI equipment and found a bunch of good pics also. Also put a bid on a bogen head to add to it once it’s done too. Finished a bookcase today and project list is caught up. So bench is free for a change to do a project for me. I’ll sit down at the drafting table tomorrow and see what I can come up with. Thanks for the info.
-- Pop
View Dennisgrosen's profile
Dennisgrosen
10880 posts in 3111 days
#3 posted 01-08-2010 05:16 PM
here is a link to some homemade tripods
http://woodgears.ca/tripod/index.html
Dennis
PopsHuckster
#4 posted 01-11-2010 12:20 AM
I found a site with the style I was thinkg about from the beginning. There’so plans or instructions but I’ve already got it down on paper and started to make a prototype leg to work with. I’ll work out the bugs before i start using the good wood for the final. Here’s the site with the original tripod.
http://www.skgrimes.com/tpod/index.htm
I won’t be doing the wood base this time. That willbe another project. I just want to make a set of wooden legs for the existing pod I already have to start.
-- Pop
View Maclegno's profile
Maclegno
224 posts in 3058 days
#5 posted 01-11-2010 03:43 AM
Please see my Photos in Lumberjock in FLICKR, might give you ideas
-- Maclegno,Scotsman in Italy
PopsHuckster
#6 posted 01-12-2010 03:45 AM
Mac…not sure what you mean?
-- Pop
PopsHuckster
#7 posted 01-12-2010 03:54 AM
Gerard…never mind…figured it out.
-- Pop
PopsHuckster
#8 posted 01-12-2010 03:56 AM
Gerard…never mind…figured it out. Macpod…neat idea.
-- Pop
PopsHuckster
#9 posted 01-12-2010 04:44 AM
Here’s what I’ve gotten done inthe last couple days. Got a short day in today because of neck spur giving me fits, but got a lot accomplished.
http://s295.photobucket.com/albums/mm149/PopsShop/Tripod%20project/
The inside angles of 15 degrees was a just a ‘that looks right’ decision. It works well with the slide piece I cut to make the inside sliding sections I’ll piece together in the future. May again to morrow if the night goes well. Have ice can sleep…..
-- Pop
PopsHuckster
#10 posted 01-15-2010 06:00 AM
OK…Thanks for all the suggestions and sites to visit for ideas. I’m about 90% done with the prototype leg. It looks and works fine. I need to add a rubber foot to the bottom section and then look at the possibility of turning a top to put the legs on instead of adding them to my existing tripod top. Right now though, I’m going to make 2 more legs and add them to my existing while i design a top.
Gere’s the finished leg (except for the foot and urethane/spar).
[IMG]http://i295.photobucket.com/albums/mm149/PopsShop/Tripod%20project/leg90percentfinished-small.jpg[/IMG]
-- Pop
PopsHuckster
#11 posted 01-17-2010 04:31 AM
PopsHuckster
#12 posted 01-20-2010 10:31 AM
OK..finished the last leg today and put them all onthe old tripod tonight. Going to try to ‘field’ test it this weekend.
http://i295.photobucket.com/albums/mm149/PopsShop/Tripod%20project/Completedlegsmountedontripodhead-sm.jpg
-- Pop
Dennisgrosen
#13 posted 01-20-2010 11:45 AM
looks great enjoy your new tripod
and have fun with it in the weekend
Dennis
PopsHuckster
#14 posted 02-01-2010 10:31 PM
Did the field trial. The legs actually work better than I thought they wood (get it wood = would)...I know…lame. I won’t give up my day job for comedy… oh heck, that’s right…I’m retired. Anyway..the only concern I had was at times because the tightening rod (1/8” brass to cam) would lift up from the cam a little when the leg was tightened down. I kinda expected this because the tightening rods had to be done as two separate pieces in each leg. I tried making it a solid piece going the whole way through the cam but the brass was so brittle it broke evey time I tried to bend it while it was through the cam. If I would have used steel rod instead of brass it would have worked fine but I went for the look of brass and the fact it would wear better in the atmosphere than steel would…plus I didn’thave to paint the brass. All-in-all I’m happy with the project. Now I’ve set the dimensions to Adobe Illustrator as a .pdf file and am working on importing some instructions and photos to the same file so you can all try your hand if you want. Probably in a couple days I’ll upload it to the site so you can download it if you want.
-- Pop
Dennisgrosen
#15 posted 02-01-2010 11:03 PM
Great to hear it worked aut for you congrat´s
Dennis
