Cheeseboard Legs
Forum topic by DonBoston posted 12-05-2015 10:57 PM 819 views 0 times favorited 11 replies Add to Favorites Watch
View DonBoston's profile
DonBoston
81 posts in 1488 days
12-05-2015 10:57 PM
So, I’ve had a request to do a custom black walnut cheeseboard for a customer, but I’m not really sure what the best way to attach the stands. The board is 2” thick, and will be finished with mineral oil/beeswax combo.
How would you attach these legs?
-- Don Boston RECreations by Don http://recreationsbydon.com
11 replies so far
View Jenine's profile
Jenine
146 posts in 1748 days
#1 posted 12-05-2015 11:12 PM
I’m going with the obvious answer here: glue.
Is there a reason you don’t want to glue them on?
-- - Montana sucks. Tell your friends.
DonBoston
#2 posted 12-05-2015 11:13 PM
hah, well ya… That was my first thought as well, but then I started wondering about dowels, or screw in anchors for added strength.
Plus it’s end grain legs gluing to side grain board. I’ve never had great success with end grain gluing.
View ShawnSpencer's profile
ShawnSpencer
81 posts in 1567 days
#3 posted 12-05-2015 11:31 PM
I’d go dowels but, screws are just as good.
-- I know you know...
View bondogaposis's profile
bondogaposis
4765 posts in 2377 days
#4 posted 12-05-2015 11:43 PM
Dowels and glue.
-- Bondo Gaposis
Jenine
#5 posted 12-05-2015 11:44 PM
Well, the entire board is glued together….so if glue isn’t strong enough, then you would have bigger problems than just the legs falling off. :)
I’ve used glue to attach cutting board legs. The only issue I had was with the first one I did and one leg slipped out of position when the clamps were on. Now I make sure I hold them in place for a full minute before clamping so they don’t move.
I also use clear epoxy to finish the bottoms of the feet to prevent moisture from wicking up from the counter and ruining my feet.
View paratrooper34's profile
paratrooper34
915 posts in 2977 days
#6 posted 12-06-2015 02:16 AM
I am guessing it is too late now, but a tenon on the feet and a mortice on the cutting board would be how I would have done it.
Jenine, the entire board IS glued together, but that is long grain to long grain orientation as it should be. You cannot glue end grain to long or end grain, which is how the feet are oriented here, it doesn’t work. Gluing lesson #1.
-- Mike
View becikeja's profile
becikeja
891 posts in 2839 days
#7 posted 12-06-2015 12:31 PM
You cannot glue end grain to long or end grain, which is how the feet are oriented here, it doesn t work. Gluing lesson #1.
- paratrooper34
Paratrooper this is my thought as well, but then how do you explain that many cutting board designs require that you glue end grain to end grain and they hold up just fine. See post: http://lumberjocks.com/topics/132306 This is puzzling to me, any thoughts?
paratrooper34
#8 posted 12-06-2015 01:05 PM
How do I explain it? Centuries of woodworking practices that dictate avoidance of end grain gluing is good enough for me. Can you provide a book or other type of source where someone advocates for gluing end grain joints? I would like to see it if so.
-- Mike
View Tennessee's profile
Tennessee
2873 posts in 2540 days
#9 posted 12-06-2015 01:36 PM
I’d be hard pressed to end grain glue those.
I’d drill a hole through the leg, countersink the bottom, and attach it with a long screw. Pretty much how most factories do it, about one inch into the main board.
Dowels are OK with glue, but they can and do snap.
View johnstoneb's profile
johnstoneb
2939 posts in 2198 days
#10 posted 12-06-2015 02:23 PM
Lighten up Top.
End grain can be glued up. It is not the strongest glue joint but it can be done successfully.
In your application I would use dowels or if you have the wood cut new legs and go with a mortise and tenon. I think there is to much potential of moisture for screws in this application.
I would use at least a 1/2” dowel if possible.
-- Bruce, Boise, ID
DonBoston
#11 posted 12-06-2015 02:36 PM
Thanks y’all, I have decided to go with dowels at this point, and will do 1/2” as suggested by Bruce.
(didn’t mean for this to turn into a an end grain gluing debate, but hey, it’s the internet so…)
