need advice on Unisaw splitter
Forum topic by mzimmers posted 12-05-2015 05:46 PM 994 views 0 times favorited 6 replies Add to Favorites Watch
View mzimmers's profile
mzimmers
212 posts in 4116 days
12-05-2015 05:46 PM
Topic tags/keywords: unisaw splitter alignment
Hi, all -
I’m struggling with an issue with my Unisaw (a 36-L31X, about 8 years old). I bought it used a year ago.
The problem is the splitter isn’t parallel with the blade. It’s slightly clockwise if you’re looking down on the table. I’ve replaced the OEM splitter with the full Shark Guard setup (which I like), and the results are the same.
My owner’s manual doesn’t cover this issue, and it’s not obvious to me from looking at it what to do. Any suggestions?
Thanks in advance…after taking a shot to the abdomen last week due to kickback, I want to get this fixed.
mz
-- M. Zimmers
View CharlesA's profile
CharlesA
3351 posts in 1999 days
#1 posted 12-05-2015 06:01 PM
I’m no expert, but it sounds like your blade isn’t aligned with the saw. I would at least start with that issue first to make sure it’s parallel.
View MrUnix's profile
MrUnix
7046 posts in 2400 days
#2 posted 12-05-2015 06:28 PM
The splitter angle should be adjustable. If you grab one of the older Unisaw manuals, it has the procedures on how to align the splitter to the blade and table, and involves a couple of screws and the eccentric rod that runs from the trunnion bracket to the back of the saw. I’d be more specific, but I have the disappearing splitter on mine, and my memory of adjusting the one like yours is a bit fuzzy :)
PS: You can find quite a few older manuals over at the VintageMachinery site.
mzimmers
#3 posted 12-05-2015 07:00 PM
Thanks for the replies, guys. Charles: my blade indeed wasn’t too well aligned, but that is now fixed. On my saw you do this by moving the table, so that doesn’t affect the blade-to-splitter alignment anyway.
Brad: there’s nothing in my manual about that adjustment; maybe they consider it beyond the scope of the typical user. If I take the motor housing off, should I be able to see this eccentric rod?
-- M. Zimmers
MrUnix
#4 posted 12-05-2015 07:11 PM
Brad: there s nothing in my manual about that adjustment; maybe they consider it beyond the scope of the typical user. If I take the motor housing off, should I be able to see this eccentric rod?
- mzimmers
That is why I suggested you look at an older manual (both the ones I have show the alignment procedure) and gave you a link to where you could find some. The rod protrudes out the back of the saw, not anywhere near the motor housing/cover. You can see it on the back in the little smiley face opening on the cabinet, and is what the splitter mount rides on IIRC. The manual describes the alignment procedure in pretty great detail (over a page long with pictures).
mzimmers
#5 posted 12-05-2015 07:27 PM
Oh, that rod. I think you’re talking about part 223 in the 3rd diagram on this page:
Unisaw Parts
That rod comes off when you go to the shark guard. I believe my problem is inside the cabinet. Still looking through the link you sent me for an explanation of that.
-- M. Zimmers
MrUnix
#6 posted 12-05-2015 07:38 PM
LOL… well, I’m not familar with the shark guard, so you are on your own with that one! But for the stock guard that comes on the saw, the alignment procedure is still pretty well detailed in the older owners manual. Since you said the problem existed prior to the shark guard as well, I figured they were using the same mount points and would use the same alignment procedures. I would imagine that the documentation that comes with the shark guard would be similar (hopefully), or maybe you could contact them and ask.
