kitchen cabinets
Forum topic by WalkerTexasRanger posted 12-05-2015 03:49 PM 675 views 0 times favorited 3 replies Add to Favorites Watch
View WalkerTexasRanger's profile
WalkerTexasRanger
29 posts in 1325 days
12-05-2015 03:49 PM
This is probably a silly question – but.—I usually build furniture but I am renovating a kitchen. I am building a lower kitchen cabinet to fit in between two other cabinets. Obviously I am wanting a flush finish. My question is what height do I cut the side pieces? Do I cut them to the finished height (less the 3/4 plywood top)? Or, do I cut them 1/4” lower and then shim the cabinets to the correct height? It is an older home and I am concerned about the level of the floor. Thanks WTR
3 replies so far
View dhazelton's profile
dhazelton
2771 posts in 2324 days
#1 posted 12-05-2015 04:50 PM
You could build your box without a base and use legs that screw up and down to get things level, then put the kick on afterward.
View AandCstyle's profile
AandCstyle
3075 posts in 2284 days
#2 posted 12-05-2015 11:41 PM
Walker, I make a separate base and shim it to level. Then set the cabinet on top of the base. Check the floor with a level to get an understanding of how much shimming might be needed and make your base accordingly.
-- Art
View Pezking7p's profile
Pezking7p
3217 posts in 1679 days
#3 posted 12-06-2015 12:40 AM
I did what dhazelton suggested when I built my cabinets. I can’t recommend this approach enough. It is so easy to level the cabinets and they have a very large adjustment range.
-- -Dan
