| Forum topic by Chris | posted 1236 days ago | 3708 views | 2 times favorited | 11 replies | ![]() |
1236 days ago |
Topic tags/keywords: turning drying green wood I have been performing a little research the last couple of days. It seems that there are several methods commonly used to dry rough green wood turnings: 1. Rough the piece and store it in a paper bag for several months (only one I have ever tried) 2. Boiling (in Water) 3. Alcohol Soaking 4. Soap Soaking 5. Microwave (constrained by size) What I would like to know is if any of you fellow LJ’s out there have tried 2 – 5 or any combination with any success? I have found threads on the issue on Sawmillcreek, Woodcentral, David Marks as well a a few others. I would be very interested to hear what your experiences have been. -- "Everything that is great and inspiring is created by the individual who labors in freedom" -- Albert Einstein |
11 replies so far
#1 posted 1236 days ago |
Yes Chris, I have tired 3, 4 and 5. My favorite and the one that works the best, for me, is the alcohol soaking. I use pure denatured alcohol, no additives. I soaked an average bowl overnight, about 8 hours. I use a 5 gallon plastic bucket, fill it with about 3.5 gallons of denatured alcohol and put up to 3 bowls in at a time. Totally submerged it. The alcohol displaces the water in the wood. After soaking, let the wood drip dry for a little while, then put it in the paper bag. It will be ready in about 2-3 weeks, instead of 4-6 months. The alcohol will wear out. It will discolor and smell after a while too. That’s when you should change it, because that means that it is more water now than alcohol. What is really neat, is when you have a fresh batch of alcohol and you put a bowl in, you can actually SEE the transference of water/alcohol in the bucket. It’s kinda’ cool. Well, at least is is to me. :) I have also used the dish detergent soaking method, and the results are the same as with the alcohol, but the bowls come out feeling rather slippery/slimy. The surfactants in the detergent supposedly displace the natural water in the green wood. The other way to dry green turned wood is to use Anchorseal or another wax based product. Turn the wood, put a light coat of anchorseal on it and put it in a rubbermaid tote. This will take a lot longer than any of the choices you have mentioned, but it is much safer as far as checking/cracking goes. Whichever way you go, know that you cannot eliminate the natural shaping of the wood. It will still oval, elongate, etc., no matter which way you go. That is, as long as you are using green wood! :) The microwave is the fastest by far, but also the smelliest and most dangerous. You should get a used microwave off of Craigslist or something and use it in your shop, and it should be well ventilated. But beware: if there is any residual metal in the wood, it will burn. If you don’t keep an eye on it, it will burn. Even if you keep an eye on it, SOMETIMES it will burn. And it stinks. Some folks keep a cup of water in the microwave with the wood to kind of even things out, but I’ve not tried that trick. I also found there is a lot more checking/cracking with the microwave method. Plus, to do BIG pieces, you will need a massive microwave! :) -- Chip -----------http://www.penmanchip.com-----------------Micah 6:8 |
#2 posted 1236 days ago |
Also, check this site out. And the AAW has some good info too. -- Chip -----------http://www.penmanchip.com-----------------Micah 6:8 |
#3 posted 1236 days ago |
Iuse #1 and #3. -- Les B, Oregon |
#4 posted 1236 days ago |
I have built a wood drying kiln out of an old refrigerator and use it to dry out rough cut blanks and first turned bowls. My favorite green wood turning process is to turn the project start to finish. I use a process of drying with compressed air and spinning on the lathe. If you understand the complexities of how wood shrinks and grain pattern this is a very successful way to turn a green piece. I can shake the birds out of a tree in the morning and have a finished piece in the afternoon. Turning the piece to a uniform thickness is the key to success. If you would like the info on turning a refrigerator into a kiln let me know. There is also some good information on John Jordans web site, www.johnjordanwoodturning.com about turning green wood. -- Those that say it can't be done should not interrupt those who are doing it. |
#5 posted 1236 days ago |
I have taken 16 inch wide used plywood and made a kiln for drying spindles and chair parts. It is 4’ X 2.5’ X 16” D with back and the 2 sides solid and the front is a piece 4’ X 2.5” cut at 6” where the 6” is at the bottom and the hinges are at the top to make a hinged door. I put weather stripping around where the door closes and a cleat in the bottom 6” piece for the door to close against weather stripping. In the top (inside) I put three electrical boxes with one bulb porcilien holders and three lampshades that clamp on the bulbs covered in renolds wrap that are turned on by a switch. The bulbs are 1-100W 2-75W and that keeps it up to between 90 and 120. I have green crest in a form ready to work and install in 4 days. I got the plan from my mentor, but drew langsner has sevral plans in his book” The Chairmaker’s Workshop” which is like mine and plans for a bigger one. Just a thought -- Humble Wood Servant |
#6 posted 1218 days ago |
i posted the alcohol procedure a while back.it is the best method i have found and i have tried them all |
#7 posted 1109 days ago |
Hi Chris, |
#8 posted 1107 days ago |
good thoughts |
#9 posted 37 days ago |
I tried the Ron Kent soap technique about 10 years ago on this chunk of wood someone gave me.
-- Quicksilver |
#10 posted 37 days ago |
wow… I forgot this thread was out there…. :) Good information. Thanks! -- "Everything that is great and inspiring is created by the individual who labors in freedom" -- Albert Einstein |
#11 posted 36 days ago |
I suspect that the species of wood is a factor in how it can best be dried. BTW, what does the brown paper bag actually do ? Does it really control the drying or is this an Old Wives Tale ?? -- Dwight - "Free legal advice available - contact Dewey, Cheetam & Howe"" |
| Forum | Topics |
Woodworking Skill Share
8798 |
Woodturning
224 |
Woodcarving
28 |
Scrollsawing
61 |
Joinery
82 |
Finishing
1538 |
3556 |
15816 |
Hand Tools
2039 |
Jigs & Fixtures
496 |
Wood & Lumber
2847 |
810 |
Focus on the Workspace
903 |
766 |
Woodworking Trade & Swap
2742 |
LumberJocks.com Site Feedback
1547 |
Coffee Lounge
6166 |
